Error -6039 \"Lost communication with hardware\"
Anyone know a solution for this one, I have PT 7.1 and it run ok for an hour or so but then I get the messages "Lost communication with digidesign hardware -6039". And I need to restart the computer, then everything is fine but later its the same error?
Re: Error -6039 \"Lost communication with hardware\"
I'd try re-seating your cards
Pro Tools HDX 2021.6.0 Lynx Aurora 16 Ross Martin PCM4222 Ross Martin Super Beast Apple Mac Pro 8 Core 2.66Ghz 16GB RAM OSX 10.14.6 http://www.keith-moore.org |
Strangly enough, I've seen this traced back to a bad (meaning non-7.x version) plug-in. Double check your plug-ins.
Also run DigiTest...if it passes you shouldn't have to reseat your cards. While in DigiTest check the firmware of your interfaces, and make sure they are all current and the same. Strange that Digi doesn't mention doing Interface firmware updates as part of the installation process (also possible I may have missed it). When I updated to 7.2 I found I had to update the firmware in my 192 IO's. |
Ok I will update to 7.2 soon also, and if i need to, how do I reset the cards? And is it a big procedure?
You simply carefully remove the PCI cards and carefully put them back in to place and check all the connecting cables are nicely seated into the sockect etc. !!Make sure you don't charge yourself with static....... make sure you touch something that is earthed before opening the box and pulling the cards out. also check the cables connecting to the interfaces from the PCI cards! carefully disconnect them and push them back in to make sure they are fully home. Chris
Lost communication with Hardware 003 | Igotsoul4u | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 31 | 03-01-2010 02:21 PM |
Lost Communication with device - increase hardware buffer - shouldn't need to. | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 02-17-2009 08:41 AM |
Error 6097 Lost communication again and again!!!! 7.3.1 | pwmachine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 12-26-2007 09:25 AM |
Lost communication error | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2005 11:43 AM |
dae error -6039 with the Audio Hardware" | AdamFrick | Pro Tools TDM Systems (Mac) | 1 | 05-01-2002 07:33 PM |
