#41
Re: How can i trust ProTools - why should i ever trust ProTools?
I am looking into an array of those SSD cards for the future that I put somewhere in the room. That's the plan, but for now the New 4TB T7Rugged for $279, is almost 1000mb/sec now as opposed to the older ones. We will see what NAMM brings or NAB. That is my hold-:) G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
#42
At the time of the incident it was a proven machine on a proven OS. The only new thing is a new PT version (increment of 1 generation), validated for the exact configuration in the most simple setup. No Plugins, no VI, no external stuff except the stinky iLok trying to connet to the internet that i disable at all times when recording. (btw. is there a easy way to permanently disconnect that MF?) Basically nothing more than recording 16 tracks of 96kHz-24bit. What a challenge for a DAW in 2023 connected to a 7000GB/s SSD! I mistakenly assumed that after thoroughly testing my configuration with the latest OS and PT (2022.x at the time of install), I could trust AVID to provide a working update of their industry standard, most expensive DAW without me having to spend hours testing from scratch. I had already recorded two days of ordinary takes with another projects on the new PT 2023. 52 Takes around 3-5min to be exact. So how much tests do i need to do before i can trust PT to hold through 30min? Avid has spent the most time of all DAW companies to adapt to ARM technology, I wrongly assumed that this would result in a stable configuration. Let's face it, they don’t seem to be in a hurry when validating hardware/software compatibilities, and demand the most restrictive requirements. I was also under the misconception that just because Logic and Reaper seem to install and work in a fraction of the time, I could expect similar from Avid. But no. My bad. For the price of a DAW i could buy a speed-support ticket from a multi-miillion-$ company since my ordinary inquiry is still unreplied. Or instead, as i did for the last two decades solve the issues on my own. |
#43
2021.10 was Rosetta only and 2021.12 also included a public beta for Native apple ARM -- BUT it's default launch was under Rosetta and you had switch it Native to test it PT 2023.3 launches default in Arm native and you have to switch it Rosetta if you want to run it that way.
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#44
Certainly by now you must realize that it isn't ProTools the app. If it was, we'd all be experiencing this, but almost no one is. |
#45
hmm.. hard to say its not the app. everything else works... coming home from the location session, PT wouldn't even start up anymore. It didn't even reached the first PT 'panel', it just froze after 1-2 seconds... i just did a fresh uninstall / install this afternoon, but hadn't time to test. Hell i have other things to work on. |
#46
Isn't it the purpose of an ARM application to run under ARM on a ARM Mac? Or: Wouldn't it be cool to get a message when PT detects non ARM components should this be delicate? In any case, i receive less meaningful messages from protools almost on a daily basis. e.g. when i open a session were i have a deactivated track that has a deactivated hardware insert on it... Quote:
I don't excactly understand the logic behind ilok searching for licenses in the cloud when they already are on the USB, though... Quote:
i mentionned it was the last before the actual 2023.3 is that true? 15 month between updates? seems plenty. i don't mind, i stay on one version for as long as possible when it finally runs stable. I'm a perpetual license buyer. |
#47
You keep repeating “no plugins” (as in none used in the session) as if that is so important… But you still don’t seem to have done much of standard troubleshooting including actually moving the .aaxplugin files out of their folder, and other things. It does not matter how long you have been using Pro Tools or opinions, or guesses about stuff, just run the standard troubleshooting steps, that is what they are there for, and we will at least know where you are at. If you have done this then please explain so clearly.
#48
I have great trouble following much of what you are talking about. ILok searching for licenses on the cloud should not be a problem if they are not needed… if you have Pro Tools or any plugin that is using a cloud based license that is your mistake, especially for a long running recording session. You are in full control of that. You set it up, fix it, use ILM to move all license activations out of the cloud.
If you have ZDT insurance on the iLok there is also some light weight communications between ILM and Pace over the Internet, this should not affect things. But when setting up any long running tracking session just fully disable networking as I have already talked about. There is potentially a lot of crap that modern apps talk over the net, including Apple certificate revocation, auto software update, sending usage metrics, etc. The best way to be sure none of that causes issues is to totally and fully isolate your Mac from the network when doing critical stuff. Last edited by Darryl Ramm; 04-06-2023 at 03:05 PM. |
#49
I have to agree. The technical approach to this has been odd, and such a strong will to blame unproven and unusual culprits suggests a lack of patience which often only gets in the way of finding a true fix. This shouldn't be complicated, yet it is.
#50
It's not the app. It simply isn't. Assuming so is only preventing you from getting to the bottom of this.
My trust C|24 PSU.... gone | Raggi | ICON & C|24 | 1 | 12-08-2020 04:34 AM |
Do you trust in Arturia/Protools 8 ? | redmount | Virtual Instruments | 6 | 02-22-2010 02:56 AM |
What Should I Trust? | Kenny Gioia | Pro Tools TDM Systems (Mac) | 91 | 01-30-2007 11:06 AM |
Which do you trust? | Sacred Spirit | General Discussion | 2 | 05-21-2005 07:04 PM |
Would you trust a plug in for this? | Dopamine | Pro Tools TDM Systems (Mac) | 4 | 12-20-2002 08:08 AM |
