Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 03-20-2009, 10:35 PM
Default Re: Temperature monitor software for OS9?
Nice work gents.
Both Mods.
Especially nice work with the router
Big fan of the Scythe stuff. it always works as advertised and the quality is always good
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 06-19-2009, 05:53 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Originally Posted by John_Toolbox View Post
My next mission is to put a 250mm fan on the side(what is now the top since it's rack mounted). Just waiting for the parts.
Thought I'd follow up on this in case there's any interest. The 250mm fan was too big and clunky to fit on the mdd G4, there's simply too much stuff crammed in that case to be able to hack it in. So instead I put the 250mm on my expansion chassis:
http://pic19.picturetrail.com/VOL103.../367520883.jpg
Also, here's a shot of the fans I added to the mdd G4:
http://pic19.picturetrail.com/VOL103.../367520882.jpg
Notice that the plastic bezel is removed, that helps with airflow, and makes mounting the fans a breeze with the little rubber feet. These two fans are right by the CPU heatsink, pretty much the hottest part of the case. This brought my idle temps down by about 7-8 degrees, and punching about 20 7/8" holes in the side of the case(the top when rack mounted) reduced temps by another 5 degrees. interestingly enough, having the plastic side cover on or off did not affect the temps at all, the big holes are enough to get the air out of the case.
Oh yeah - look at the hole at the bottom of the case (right of the picture)... that's where I hacked in my stealth serial port
Old 06-19-2009, 09:26 PM
M.Brane M.Brane is offline
Cool! *pun intended*
A cool running Mac is a happy, and long-lived Mac.
HTML code is On
Eucon Ver.3 software & Control Monitor button workinstiff Artist Series 2 09-07-2013 11:12 AM
AVB status monitor software? xcx VENUE Live Sound Systems 0 02-14-2013 01:45 AM
BOOYAH!!! Software Monitor Shut Off!!! Dirt_ Pro Tools 9 1 02-24-2011 02:12 AM
Left Monitor Fuzz - Software problem? SoundtrackArcade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-02-2009 11:34 AM
Best software to monitor your cpu temp? GuitarEasley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-29-2003 10:06 PM
