Anyone seen the new 003+?
Just wondering if it's hit the stores yet - the Digi press release has said "Now Shipping" for over a week now.
Re: Anyone seen the new 003+?
No disrespect but that's a press release. It could even mean it left on a slow boat from China! No retailer web site that I could find even mentions it.
my issue is that on the 002/003 you cannot bypass the mic pre's when running into the line inputs of 1-4 so there is a noise floor issue there which is pretty significant. So if this one means 8 inputs worth of this same issue that means I wouldn't touch it with your 20ft pole. If they had come out with a box that had either 16 inputs of ADAT or if you really want to dream, 16 inputs with SMUX support, then we'd be talking. It just blows my mind that M-Powered people can have this right now as we speak...... WTF? Not SMUX but 2 sets of ADAT inputs or the option of up to 192K using the Anaolg ins for $700.
http://www.sweetwater.com/store/detail/ProFire2626/ We pay $1550 for 48k and only 1 set of ADAT. Thanks Digi for this cutting edge new device! And this would be just what the docter ordered, for $400! http://www.sweetwater.com/store/clos...reLB--Back.jpg Nope not for LE, you would be much too productive with such a device. Can't have that now... I'd pay $2500 for that same exact device to work on LE.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
ok... so then it isn't a legitimate issue because "a lot of gear in this price range does the same thing"? I guess I could be more specific, buy a used Digi 002 and an Apogee Rosetta (or any 8 input A/D converter) so that you can have at least 12 channels of non tainted input and 4 inputs of noisy input, instead of 8 inputs of noisy input and 8 inputs of un-tainted input with the 003+.
I have to agree with Oddsare on this one
The 003 preamps are "Ok", but Im using a Soundcraft 1600 and sometimes a TL-audio for mic preamps. I wish I could bypass the 003 preamps totaly! Perhaps with a bypass modification? then I would be able to have 8 analog inputs and 8 digital inputs with my own choice of preamps! Either way, the analog stages arent the best, and could be improved. I've checked these guys out : http://www.blacklionaudio.com/digi003_mod.html I wouldnt mind ordering a custom mod with a bypass function in the 003 preamp stages. tasty huh?
Macbook 2,4 GHz Intel Core 2 Duo/4 GB RAM OS: 10.5.5 PTLE 8.0 MPT 2.0 003 Factory/Mbox |
From the specifications here:
http://www.digidesign.com/index.cfm?...64&itemid=6243 It looks like you get to choose to use the mic preamps (XLR) or line/DI Inputs on any of the 8 channels. Now the question is does it truly bypass the mic preamps by using the line/DI inputs of is it just a 1/4" plug that goes through the same circuit. I see a line/DI switch on the front panel but does that mean all 8 inputs are either mic inputs or all 8 are line/DI? I would think it would be useful to be able to select some as mic and some as line/DI. Perhaps there is a way to do this that I can't tell by just looking at the front panel.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
http://www.zzounds.com/item--DGDMX003RPLUS http://www.audiomidi.com/003-Rack--Factory-P11594.aspx http://www.8thstreet.com/product.asp...dio_Interfaces I didn't have any problems finding it. Press releases are released for a reason... |
So you think, well big deal, it's so quiet, but add that noise to 48 tracks and you will wonder why your mixes are muddy. So ultimately I was saying it is easier to avoid using 4 channels of this type of Input such as on the 002/003 than it will be to avoid 8 channels of it on the 003+. If you are looking to keep your LE system as "PRO" as possible and use high quality external mic pre's then you would want to stay away from the 003+. If you are looking for the least expensive way to get 16 inputs into LE and are bound and determined to buy brand new, get the 003+ and something like the Digimax I guess...
