Matrix Mixing
I am a new Venue user and was working with with matrix mixes. Getting things into a matrix is no problem, but how do I get the matrix back to an input, main bus, or group bus? Does the matrix mix have to be sent to an hard output and brought back in?
Demetrius |
Re: Matrix Mixing
You have to physically patch it back in.
Dave
David Stagl - Mixer | FOH Engineer http://www.staglproductions.com http://www.goingto11.com |
Re: Matrix Mixing
Somebody correct me if I am wrong, but you can also use a plugin. Set the input of the plugin to Matrix output. Set the plugin output to feed into the channel (or wherever) you want.
I'll let somebody chime in on a good plugin recommendation. I believe you can also bypass the plugin so it isn't consuming resources. But I haven't tried that yet. One thing to be very careful of is path loops. For example if the Left / Right mix feed into the Matrix, and you feed the matrix into a channel, make sure that channel doesn't feed into the left / right mix. -craig |
Re: Matrix Mixing
I think you are right Craig. As far as plugins go I would suggest something from the digirack tools. There is a plugin that is called "trim" that is just an attenuator. I can't see something like that taking up hardly any dsp.
Re: Matrix Mixing
Thank you. I will be working to see how I can use this capability.
Demetrius |
Restore the Matrix! | Mano | ProControl, Control|24, Command|8 | 13 | 10-27-2004 03:35 PM |
Midi Matrix?? | Pet Umbrella | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-11-2003 01:02 AM |
M-S matrix | tirt1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-01-2002 08:30 AM |
where is the matrix ? | sandman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-12-2001 12:39 AM |
Matrix Window.... Please help!! | ProTooler | Digidesign Hardware & Software | 1 | 11-14-2000 10:27 AM |
