Eleven Rack Editor not letting me change some parameters
Hello,
Today I received a brand new Eleven Rack already expanded. I installed the drivers on my PC (Windows 7 x64, in a powerful machine I used to host Pro Tools in, Windows is clean and updated) and then executed toe ERXP and installed the Eleven Rack Editor. The Editor seems to be working fine, except it doesn't allow me to change some of the parameters. These are things I cannot change in the Editor no matter what I do: - Volume pedal: I can change the position of the pedal, but not the little bypass switch or the min volume or lin/log switch. - Wah pedal: I can change the position of the pedal, but not the bypass switch. - All other pedals: I can change the on/off button, but none of their parameter buttons respond to my mouse. - Amps: I can move the amp knobs (treble, mid, bass, etc) but I cannot change gate knobs, amp type, cab type, output knob, volume or bright switches. - Cab: I can change breakup and mic type and axis switch, but I cannot change the bypass switch. - FX2: I can move knobs but the bypass button doesn't respond. - Reverb: Everything seems to be working fine here. If I change from the Eleven Rack directly the things I cannot change in the Editor, it works and the editor reflects it. This is not the first Eleven Rack I buy. I had one a few years ago and I don't remember having this problem with the Editor. Any ideas on what might be happening or how to resolve it? Thanks in advance for any comment! Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
Re: Eleven Rack Editor not letting me change some parameters
As a little update: In the same exact PC, I booted another Windows 7 x64 partition. I installed the Eleven Rack editor there, and it worked without problems.
So, I think something went wrong in my other Windows partition with the Editor setup, but I have no idea what it can be. I already tried uninstalling pace drivers, the Editor, the Microsoft Visual C++ Redistributable, rebooting and letting the Editor setup install all of that. No luck! Francisco
Eleven Rack Editor | 57Stratocaster | Eleven Rack | 4 | 08-22-2016 11:12 AM |
Eleven Rack Editor | joeleemusic | Eleven Rack | 2 | 06-07-2014 08:12 PM |
Eleven Rack Editor Now Available | Avid | Technical Alerts | 0 | 01-23-2014 09:02 AM |
Controlling Eleven Rack parameters | Relayerjb | Eleven Rack | 7 | 09-23-2011 07:54 PM |
Eleven Rack doesn't change sound output when I change to a new rig | Jlambton | Eleven Rack | 4 | 02-28-2011 11:51 PM |
