Old 01-18-2021, 02:35 AM
breenizm breenizm is offline
Default Catalina & 2020.12: m4a import semi-broken?
Hi
We're on Catalina 10.15.7 and can't get an m4a to convert/import or drag & drop in either 2020.11 or 2020.12;
I see on the update changelist that m4a import should now be supported again, and strangely enough, if I 'convert' the m4a into another presumably reencoded m4a in Apple Music / iTunes, it seems to import just fine.
Anyone have any idea why this might be, or even better, a fix for it?
With all the non-professional recordings I've had to deal with since the pandemic began, I really need to be able to work with m4a as easily as I used to.
Old 01-26-2021, 06:58 AM
francois's Avatar
francois francois is offline
Default Re: Catalina & 2020.12: m4a import semi-broken?
Go get shutter encoder.
Free ap.
Takes care of all your convertion need .
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
Pro Tools 2020.11 with Catalina; How is it? Thenewexhibit Pro Tools 2020 12 12-16-2020 01:35 PM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
2020.5 and Catalina 10.15.5 dmitch macOS 1 06-30-2020 09:38 AM
2020.5 & Catalina 10.5.5 ac30fan Pro Tools 2020 4 06-28-2020 05:27 PM
Is 2020 better w Catalina? Rectifried Pro Tools 2020 13 04-06-2020 09:28 AM
