Old 02-28-2003, 11:53 PM
dmaxj dmaxj is offline
Default 001 bleed
Does anyone with a 001 ever experience track bleeding when recording 2 or more tracks???
I am getting this and it's annoying.
I am running XP on a PC with PT 5.3.1. I have my 001 connected to the buses on my console. I am sure that my buses are clean because I still use them to track to an ADAT deck ( no bleed).
Thanks
Old 03-01-2003, 05:17 AM
where02190 where02190 is offline
Default Re: 001 bleed
Never. Are you sure it's not headphone leakage or console bleed?
Hope this is helpful.
Old 03-01-2003, 10:50 AM
No, I am only recording instruments punched in at the busses ( no headphones). The console is not bleeding, because I don't get bleeding when I record to an ADAT recorder.
I may have figured it out, though. I think that the INPUTS on tracks that PLAYBACK have to be set to NO INPUT or the playback data bleeds onto to new tracks when recording.
Peace
Someone else verify.
Old 03-01-2003, 11:48 AM
Lalaman Lalaman is offline
<font size="2" face="Verdana, Arial">This would mean no connection to the problem. Check if outputs of the playback tracks might be routed either to the recording tracks or to aux channles that lead to recording tracks.
Lalaman
Old 03-01-2003, 02:44 PM
All of the playback tracks from PT are routed to Stereo OutPut 1&2 (No Auxes). I am recording on inputs 3,4,5,6,7,8.
The point I was making is that on the PLAYBACK tracks from PT, I still had the INPUT selected during playback. The recording tracks are active too with the INPUT selected. I could still the other track being played back.
Sounds confusing ??? Basically - turn off the INPUT of any PLAYBACK track from PT, or you may experience some bleeding.
Peace
Old 03-01-2003, 03:37 PM
JMS40 JMS40 is offline
I don't doubt what you're hearing, but I don't understand it.
The only way the input selection should come into play is if a track is record enabled.
I often have several "playback" tracks set to the same input, with only one rec enabled at a time, and have never had the problem you describe.
Old 03-01-2003, 08:00 PM
problem solved...
thanks
Old 03-01-2003, 08:04 PM
Stone Knife Stone Knife is offline
So what was it that caused this situation?
Old 03-02-2003, 11:33 AM
I had the monitor input punched to a BUS submix out - The same BUS that was sending to the 001. I also, found that a new microphone that I had hooked up across the room was still on and recording while I was tracking... Silly me....
Engineer error... I am glad it was not the 001 - I was about to be pissed...
Channel Bleed bubbiesdod Pro Tools M-Powered (Mac) 0 01-25-2007 06:41 PM
001 Channel bleed Noiz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-21-2005 06:01 AM
Channel bleed in 001 Noiz2 Post - Surround - Video 0 04-20-2005 08:53 PM
track bleed Jeff Harris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-09-2003 01:55 PM
hi-hat bleed Rudy Michael Tips & Tricks 32 01-03-2003 12:32 AM
