Equality strange problem
I am noticing a very strange bug on my Equality plugins. I am using the RTAS (low latency) in about 60 tracks. Sometimes, I have not figured out what causes the bug, if I open the pluging to edit it with a mouse (like pull down the node of a band, or change the slope of a filter etc), the mouse pointer has to be clicked "in a space that is higher" than where the actual "button" or "volume pot", or any of the nodes of the bands exists. So it is like the entire plugin (the GUI of the plugin) is miss-aligned to where the mouse actually triggers each action. I have had 2 instances of the Equality open at once, and one will have the bug and the other will not. At some point, after closing and re-opening the plugin, the bug will go away, and the GUI re-opens normally aligned but sometimes it had gotten so stuck that I had to delete the plugin from the track .
For the developer: I am on PT9 HD2 Accel on an 8 core Mac 2.25 Ghz, 6 Gigs RAM, Snow Leopard |
Re: Equality strange problem
He usually replies within hours, and he surely can help you better, than anybody here.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
I first noticed this behavior after the update to PT9, but that might be just a coincidence. arvid in stockholm |
DMGAudio updates for EQuality, EQuick and Compassion | DaveGamble | Post - Surround - Video | 8 | 07-02-2013 09:50 AM |
Equality and PT10 HD | digidub | Post - Surround - Video | 5 | 01-03-2013 03:17 PM |
Changing Equality parameters causes PT 10.2 to crash | garnoil | Post - Surround - Video | 3 | 07-06-2012 10:51 AM |
DMG EQuality with D-Command | ChrisBurdon | Pro Tools TDM Systems (Mac) | 0 | 02-07-2012 12:26 AM |
Equality for all post mixers | dr sound | Post - Surround - Video | 103 | 08-19-2011 08:28 AM |
