Old 04-09-2001, 07:50 AM
EHeiberg EHeiberg is offline
Default IAC ch. 2-16 bus crashes
This seems to be a repeatable bug- I've done on an 001 system running 5.1 and a TDM system running 5.01 : set a midi track to an IAC bus channel 2-16, arm it for record-- and boom, frozen. IAC channel 1 works fine. Is it an OMS thing?
Old 04-09-2001, 12:33 PM
mig 15 mig 15 is offline
Default Re: IAC ch. 2-16 bus crashes
I have exactly the same problem-I want to run
vsc3 and reason(as a multi-timbral rack).Anyone?Thanks.
mig
www.jameseller.com
Old 04-11-2001, 02:59 PM
EHeiberg-I found a way to make this work which is to assign the IAC busses as follows;
1-Virtual sound canvas
2-IAC bus 2 (no instrument assigned)
3-Tokyo/Vibra 1000 (or blank)
4-NI Soundforum (or blank)
Seems to work fine,no crashes.Also using reason on the vsc bus(not at the same time!) and both work multitimbrally.Been working up large midi arrangements all day with no problems.Maybe the following bus has to be empty?Who knows.
Hope this helps.
mig
www.jameseller.com
PT 8.1 crashes TAFE Pro Tools TDM Systems (Win) 4 11-08-2009 08:59 AM
7.4 crashes manbeargun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-15-2008 02:13 PM
G5 crashes CKoszuta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-19-2004 11:08 PM
m box crashes johnny5isalive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-06-2004 10:51 AM
G4/733 & MTP USB Crashes SOR Pro Tools TDM Systems (Mac) 2 10-04-2001 07:56 AM
