midi controller not working?
hello all,
haven't used my oxygen controller in a few months, worked fine last time i tried. controller works when i open some plugins in stand-alone mode like kontakt or minimoog v original. today, not responding in PT. running PT 8.05 my mac is running 10.6.8 tried several instruments like vacuum or mini grand and they work in the session, just don't recognize my controller. how do i trouble shoot? where do i reconnect the midi controller? thanks for any help. terry |
Re: midi controller not working?
MAKE SURE your MIDI thru is active. In PT Prefs, MIDI, under BASICS, make sure your "Default Thru Instrument" is assigned to either it's own instrument channel, or select "first selected MIDI track". These may help you. If that doesn't work, go into your Utilities in your Applications folder under "Audio Midi Setup" and check your settings there. Your Oxygen should show up. If not, add the instrument you need. Good Luck.
Absence of evidence is not evidence of absence...the truth is out there. |
checked everything that was recommended,
no luck yet. controller works with plugins in stand alone mode, does not work when open plugins in pro tools. t |
Also, make sure that you are using an "instrument" track for your controller to operate. ie: if you have soft synths/samplers/Reason/etc, those have to be on an instrument track...in case you haven't done that, but you probably have.
I had the same problem and I solve it using a powered USB hub, I connected my usb keyboard (m-audio prokeys 88) to the hub and connected the hub to my mac (retina) then everything works, Im using pro tools HD11, and OS X 10.10.4
Midi Controller not working | davgrn | Windows | 2 | 12-01-2013 01:59 PM |
Midi controller not working! | SonnyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-31-2011 04:10 PM |
midi controller not working with ez drummer | alzuka | MIDI | 3 | 08-18-2009 07:50 PM |
Midi Controller not working | Precava | Pro Tools TDM Systems (Win) | 7 | 12-11-2005 12:01 PM |
USB MIDI CONTROLLER NOT WORKING | NickFLZ | Pro Tools TDM Systems (Mac) | 7 | 07-08-2003 08:48 PM |
