Old 03-27-2009, 08:40 PM
K.I. K.I. is offline
Default NewMacPro Nehalem!!
Hi.
I obtained it.
New MacPro.
SSD of the OCZ Co. was installed in this.
PT8 was installed there.
Many installed Plug-In.
It operates at present without trouble.
MySystem
MacPro2.96G
Digidesign EB7 PCIe-to-PCIe Expansion Chassis
andAccel7
D-Con48ch
Old 03-27-2009, 11:45 PM
soundeq soundeq is offline
Default Re: NewMacPro Nehalem!!
I just got a 4 core Nehalem mac pro....
Pro tools HD 8 Cs2
Had a delay issue today.... Delay compensation was unchecked, and there was obvious delay on a easy IO routing basic in/out no plugs.
"long" delay comp was enabled in the playback engine, but it was definitely set to off in the options drop down.
Restarted, cycled IO and clicked the "long" to none in playback engine and seemed to fix the problem. Totally random, nothing strange going on besides opening and loading different sessions.... Spooked me, and makes me wanna double check my other sessions from yesterday...
I might go back to my 7.4 computer..
I could be wrong...
Old 03-28-2009, 12:17 AM
ajastudios ajastudios is offline
Mac Pro Nehalem 8 core 2.26 Pro Tools HD1 8.0cs2!
Inconsistencies with rtas buffer at 16 cores! Lowering to 64 improved stability.
Old 03-28-2009, 03:55 AM
crizdee's Avatar
crizdee crizdee is offline
64 cores now i am jealous
chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-28-2009, 12:01 PM
no no 8 cores, virtually 16 with hyperthreading, and a rtas buffer rate of 64.
PT HD 7.4.2 on MacPro Nehalem w/ 10.5.8? technerd Pro Tools TDM Systems (Mac) 1 09-11-2009 12:19 AM
anyone using a nehalem mac pro with 7.4.2 sucessfully? diamondschwin Pro Tools TDM Systems (Mac) 3 06-11-2009 06:52 AM
New Nehalem + TV = FAIL Sean Russell Pro Tools TDM Systems (Mac) 3 06-10-2009 09:02 PM
Nehalem YES - but which one? Peterjk Pro Tools TDM Systems (Mac) 21 05-28-2009 07:03 AM
Nehalem MAc Pro Configs JSR Pro Tools TDM Systems (Mac) 15 04-18-2009 02:10 PM
