Old 02-07-2008, 09:38 PM
henno henno is offline
Default 003rack Digirack plugins missing after upgrade to 7.4
Helllo
Can someone advise me how to get the chorus and flanger plugins back...
I opened a ticket with support no reply...3 weeks ago
I have checked around apparently, the digirack suite plugins is incorporated in the PT install, but since 7.3 I lost these specific
plugins.
I am running
003 rack on G5 1.8 single processor with 1.5m ram.
7.4 LE
The flanger and chorus dpm files are there in the folder (with all the other dpm's) but these plugins do not appear in the track inserts for use.
I want to resolve this issue because I maybe unaware of any others problems.
Thanks
john
Old 02-08-2008, 01:04 AM
tamasdragon tamasdragon is offline
Default Re: 003rack Digirack plugins missing after upgrade to 7.4
With 7.4 you should update to cs2. After that in the download area you can find some plugin update file, you may need them. If none of those works, than try the tech support utility, which can trash your prefs and databases. Even you can download those plugins' installers and try to reinstall them.
Report back how your troubleshooting goes.
Tamas Dragon
my blog:Tamas Dragon
Old 02-08-2008, 07:26 AM
Camilo Toledo Camilo Toledo is offline
The installation process gives you an option to install only the plugins, or fix a wrong installation.
Camilo Toledo
Old 02-08-2008, 08:28 AM
Ok I see progress actually happening now,
I did the cs update ages ago, Im not sure which is the plugin installer on the digidesign website for the digirack audiosuite.. as I thought it was installed during the PTle 7.4 install (built in the software).
AND
I DO NOT have chorus.rsr or chorus.dpm.rsr
so How do I get that ? generated if not via 7.4 install??? FYI I am on mac using 10.4.xx latest (tiger)
thanks for your assist here guys...
John
Old 02-08-2008, 09:56 AM
DigiTechSupt's Avatar
AND
First, you're on a Mac and posting in a WinXP forum, so I'm moving this to the proper forum.
Second - the 7.4 installer should install DigiRack plug-ins. Try running the installer again and make sure the DigiRack plug-ins are checked during the install.
You can check if the plug-ins are installed by going to MacHD>Library>Application Support>Digidesign>Plug-Ins. If the plug-ins are in that folder, then you should try trashing preferences so that the plug-in data can be re-cached.
Avid Audio Tech Support
Support FAQ
Old 02-08-2008, 03:44 PM
thanks for your reply,
before I do anything stupid please advise what directory the plist is in?
Search found several folders with plist in them
osx
john
Old 02-08-2008, 03:45 PM
osx
john
Old 02-08-2008, 04:50 PM
Ok Ive returned to new PTLE 7.4 install clean
What plist to delete as I still do not see the Chorus and flanger plug in
Old 02-08-2008, 06:03 PM
bump plist question
Old 02-11-2008, 10:21 AM
registration issue resolved
please what plist to delete to reload all plugins
trash what and where the preferences>.....
installed pt 9 digirack plugins missing musicmixer04 macOS 2 08-17-2012 01:34 PM
DigiRack plugins missing after updating to 7.3 stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2007 10:27 AM
Do I need to upgrade Digirack plugins with PTLE 6? rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-29-2004 12:10 AM
PT6 Digirack Plugins MISSING??? EarnestBliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-17-2003 01:19 AM
PT6 Digirack Plugins MISSING??? Chris Coleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-14-2003 05:32 PM
