Old 11-23-2004, 10:37 AM
emelare emelare is offline
Default Transport Window Gone
I'm running dual monitors on windows xp pro and I can put the mix window on one and the edit window on another. The small transport window (with the click track functions) has simply got up and disappeared. On the drop-down, it's listed being available and is checked. When I minimize the edit and mix windows, I still can't see it. It was there yesterday, but is gone today! Any thoughts?
Old 11-23-2004, 10:38 AM
Default Re: Transport Window Gone
Try trashing your preferences file.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-23-2004, 01:12 PM
Aussie169 Aussie169 is offline
You'll probably find it's been bumped off the edge of the screen. Up your screen area to 1280x960 or maybe even more and you'll probably see it. Drag it to the middle and reset your screen area.
Old 11-24-2004, 06:38 AM
Polyph Polyph is offline
I have been having the same problem from time to time but not only with my transport but my plugin windows as well. Ill try some of the fixes mentioned above. Lord knows everything else hasnt worked.
Old 11-24-2004, 07:09 AM
bkremer bkremer is offline
Don't worry, I run two monitors also and sometimes windows try to run away. Just delete your preferences file. Technically, LE doesn't support dual monitors, but we all know better
Old 11-24-2004, 11:32 AM
Might be a dumb question, but I havent done that before. How do I go about doing that?
Old 11-24-2004, 11:45 AM
Look for the PTP file in the folder:
C:\Documents and Settings\Your User Name\Application Data\Digidesign
Rail
Platinum Samples
Can't see transport window Bookerv12 Pro Tools TDM Systems (Mac) 9 06-20-2010 11:53 PM
Transport Window and Color Selection window lost cd_audio_mix Pro Tools TDM Systems (Mac) 6 11-26-2006 10:58 PM
where is my transport window??? surely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-10-2004 07:32 AM
how to put transport window inside edit window? keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-18-2004 06:47 PM
Transport window jeffreym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-14-2003 12:34 PM
