Old 03-02-2010, 09:53 PM
ernestseeker ernestseeker is offline
Default MIDI Controller Woes!! Please Help!
I was using my MIDI Controller last week with ProTools. It's a Roland FP-5 Digital Piano connected to my 002 with a MIDI cable, and has worked beautifully in the past.
Starting yesterday, I could not for the life of me get it to trigger anything in ProTools (Addictive Drums, Sylenth, not even SampleTank or Xpand) -- which is odd considering it tests fine in the MIDI Studio Setup, and DOES trigger Reason ReWired through ProTools, and triggered everything in Logic when I tested it with that.
I've tried turning on and off every component in every order, restarting my computer, trashing my "com.apple.midi.123456789.plist" and "com.apple.audio.audiomidisetup.plist" files under Library>Preferences... Nothing has worked
I am completely, 100% confused and flustered. Does someone have a clue why this would suddenly be happening and what I can do to fix it???
Old 03-03-2010, 07:18 AM
systemexclusive systemexclusive is offline
Default Re: MIDI Controller Woes!! Please Help!
Just personally, when i have MIDI troubles i am doing the next checks:
1. Check that MIDI messages comes into operating system, using MIDI monitoring software i.e "s n o i z e : MIDI Monitor"
2. Check MIDI inputs enabled\disabled in Pro Tools MIDI preferences
3. Check MIDI input filter in Pro Tools MIDI preferences
4. Create new session from scratch
5. Enable MIDI Thru
6. Record enable Instrument track...
7. Instrument should sounds...
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8
mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop
r3, microQ, Albino3, impOSCar, Structure
m1active 520 & sub gw s750, deq230, cx2310
MIDI woes jkeefauver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-07-2007 04:13 AM
Need help with midi woes hecatomb MIDI 7 03-02-2007 03:18 AM
MIDI Woes. WorkingEngineer Pro Tools TDM Systems (Mac) 0 12-03-2004 04:45 PM
MIDI woes CStern MIDI 7 10-09-2001 11:37 AM
MIDI woes PHead14006 Pro Tools TDM Systems (Mac) 0 07-31-2001 06:15 PM
