Old 04-29-2021, 02:43 AM
bassmagnetic bassmagnetic is offline
Default 2021.3 new error "playback could not be started because of an engine reset"
I have a new error that keeps popping up about every 5 mins...
Anyone else having this new issue, know any fixes?
Old 04-29-2021, 04:19 PM
colinato colinato is offline
Default Re: 2021.3 new error "playback could not be started because of an engine reset"
It happened to me a couple times on an iMac I'm working on today. I don't have any other info on it though.
Old 04-30-2021, 12:44 PM
Tough to offer help with zero details on the setup Shooting from the hip, is it a Windows setup and you didn't disable Power Management on all USB ports?
Old 05-13-2021, 06:31 AM
happening like once every 5 mins... its annoying...
thanks albee1952... I hadn't done that, but I now have but it didn't make any difference...
Windows 10 PC
ASUS Prime X299-Deluxe
i9-7980XE 18 Core
RME 802
Old 06-14-2021, 10:40 AM
Kaister Kaister is offline
This happens to me, too.
Sometimes I don't get the error message, only the rotating mac-ball, and after 5-10 secs I can work again. Still quite frustrating.
I'm on a 2015 Retina 5K 27" iMac, Quad-Core i7 4.0 GHz. Pro Tools 2021.3.1
I followed the optimization guide and trashed the preferences. No difference.
Old 06-14-2021, 10:43 AM
I unchecked "Optimize Performance at Low Buffer Sizes" in the Playback Engine window. It seems the error message doesn't pop up as frequently now, but I'm still checking.
(Buffer size is set to 1024.)
PT Ultimate 2022.10, MTRX Studio, MacPro 3,2 GHz 16-core (2019), Eucon 2022.9, macOS Monterey, Avid S1, Avid Dock, Dolby Atmos Home
Old 06-18-2021, 07:30 AM
seanmccoy seanmccoy is offline
I've seen it a number of times, but it's not chronic. For me, any playback stoppage like this generally happens either when I've first loaded a large session, or when I'm doing rapid-fire editing. And mostly—if not exclusively—when there's video involved.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 09-13-2021, 05:34 AM
Bokir Bokir is offline
I'm starting experiencing this, it's annoying. It's happen randomly. Any kind of session size (small or big)--but it's always with picture. I have try moving the session to directly attached SSD, but still happening.
It started to happen after I upgrade the OSX (Supplemental update) and the ProTools (2021.7).
Any solutions? Thanks.
Satrio Budiono
FourMix JFS
Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4)
Old 03-09-2022, 03:08 PM
Mike Farnan Mike Farnan is offline
I'm also seeing that error on a newly set up rig. It's a Mac Pro (Late 2013), with an HD Native card in a Thunderbolt expansion chassis. Any ideas?
Michael Farnan
Desiderata Media, Inc.
Old 06-02-2022, 09:25 AM
Jaim Jaim is offline
I am experiencing the same thing with a 2018 mac mini (64Gb i7) and an HD native card in a Sonnet Echo III thunderbolt expansion chassis. Did you solve the problem?
HTML code is On
"The current playback engine does not support a sample rate of 0kHz" Kahlil_J Pro Tools 12 1 01-27-2016 10:04 PM
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
"Current playback engine does not support a sample rate of 48 khz" pribb1 Third Party Interfaces 28 07-01-2015 08:47 AM
"current playback engine doesn't support sample rate" terracestudio Windows 2 04-17-2015 02:37 PM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
