Old 02-25-2015, 04:08 PM
sectorsteve sectorsteve is offline
Default changing the bit rate?
The default in my PT8 is 48khz. I want it to be 44. How do you change this?
if i go to session in drop down menu theres no option to change this setting.
thanks
Old 02-25-2015, 04:33 PM
mesaone mesaone is offline
Default Re: changing the bit rate?
To start a new session at whatever sample rate:
  1. File > New
  2. Configure your options (format, sample rate, bit depth, etc)
  3. Click OK
To convert a session you already have:
  1. File > Save Copy In
  3. Select Items to Copy > Audio Files and Items to Cop[y > Audio Files> Convert to Specified Format
  4. Click OK
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 02-25-2015, 05:04 PM
albee1952 albee1952 is online now
And now that you have the method, I must ask WHY you need this(or why you THINK you need it)? I can certainly understand wanting a 44.1K/16 bit final audio file to burn onto an audio CD, but that's a conversion that should/would be done at the end of the mixing process, not at an early stage
Old 03-01-2015, 04:16 PM
THanks for that!
havent used PT for ages and for some reason the default is set to 48khz. From memory this setting causes problems when using some software. I want it set at 44.1 permanently.
Old 03-01-2015, 05:21 PM
Originally Posted by sectorsteve View Post
THanks for that!
Can't imagine what you are referring to here. 99.5% of my work is done at 48K and I much prefer it to 44.1 as it extends the high end a bit, without placing a serious burden on the system(unlike trying to run a 96K session). I made the move from 44.1 about 3 years ago and have had no reason to regret it. The default sample rate is sort of a misnomer as you set the sample rate, every time you create a new session. Having said that, on my system, going back as far as I can remember, the sample rate has always defaulted to whatever I selected the last time I create a session. Maybe some details about your setup would help someone give better advice?
Old 03-02-2015, 04:46 AM
Interesting. Well this project I'm working on now is all being tracked to tape and mixed only in pt, so I guess I should use the higher bit rate then.
The only reason I was a bit worried was thT bfd2 didn't like higher bit rates.
Since m not using and plug ins except altiverb, I'll go hard on the higher bit rates!
Old 03-02-2015, 05:47 AM
Bill Denton Bill Denton is offline
I fear you are a bit confused...there is no "bit rate".
There is "bit depth"...typically 16, 24, and 32.
There is "sample rate"...typically 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 192 kHz.
And I will leave it to Google to explain further...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 03-02-2015, 06:22 AM
Sample rate bit rate whatever. I'm sorted, you people no longer have to post on this thread. Cheers though.
Old 12-21-2021, 04:58 AM
[email protected] info@andrewhubbard.com is offline
Hello lovely people. Bit Depth. Sample rate. BIT RATE is a 3rd measurement. I need mp3's at 192kbps or more. I can't see a way in PTs HELP!!!!!!!
Old 12-21-2021, 05:11 AM
JFreak's Avatar
JFreak JFreak is online now
Thanks for reviving a thread over half a decade old.
But since you did, let me give some insight for some that may be confused:
1) The difference between 44.1 and 48kHz sessions is negligible. It only means that as per Nyquist's theroem, 48k session can handle frequencies up to 24kHz whereas 44.1k session can handle frequencies up to 22.05kHz. Why is this even important? Because of AD conversion and filtering that happens before audio reaches WAV file. The imperfections are 2kHz higher if you use 48k session and therefore with a good monitoring you may (or may not) hear slightly more "open" top end in your material.
2) Bouncing your final can be done from any sampling rate and bit depth session to any sampling rate and bit depth. If you have a CD project in mind, you can work in other sampling rates than 44.1k and other bit depths than 16bit. Sample Rate Conversion involved does not affect sound quality if your stuff is mixed right (and if you are unsure let mastering engineer do the final step).
Janne
Changing The Sample Rate DoctorBuddha Tips & Tricks 9 06-16-2010 02:40 PM
Changing Sample rate from 96 to 44.1 langelo68 General Discussion 4 08-29-2009 08:18 PM
Changing the Sample Rate jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-12-2007 05:07 PM
Changing sample rate? chino_151 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-21-2005 05:15 PM
changing sample rate in USD set up FossFace Pro Tools TDM Systems (Mac) 3 08-13-2004 04:31 PM
