attention pt10 early adopters...is it better than 9 on W7?
My thread title says it all. I've been running plain vanilla PT9 on my W7 I7 rig and I still experience much bugginess from time to time. I DO NOT always point the finger at PT, since the Win7 OS is still extremely fussy compared to my Macs which "just work". I'm polling to see if PT10 feels more stable or is it just too early to tell. In my case I'm using the win7 rig for music creation and the Macs for post Production Work...where I have not time for down time.
Personally I'm waiting for the 14 day trial to see how it behaves with my own set of plugs and interface, but if you have any experiences worth sharing by all means LMK.
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
Re: attention pt10 early adopters...is it better than 9 on W7?
Hi Wilson, I'm trying to kill it on Win 7 but so far no luck. PT10 on bootcamped MacBook with CPTK2.
I have been running PT 10 for 2 weeks now with no issues. I have yet to receive any error codes (to date).
I was using PT 9.0.3 prior to upgrade. For me, this has been the most stable version since I started using PT at version 7.3. Lou
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD Catalina 10.15.7 Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors. Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves. |
Issues ...
Launching takes forever. Closing PT10 also takes forever.
Some graphic issues with meters. I/O recognition is very buggy. I've done all the tweaks & I'm using Win7 (32bit). PT 9.0 was much more stable on my system.
Win7 (32bit)/ Asus p6t Deluxe v2/ Core i7 920/ Kingston 128gb SSD/ Seagate 1tb (x3)/ Crucial Ballistix 6GB 1600mhz 8.8.8..24.1N/ EVGA Nvidia Geforce 9500 GT 1GB/ Pro Tools 10.2/ Reason 6/ Reaper 4.22/ UAD2 QUAD + UAD2 Solo (x2)/ Lynx Aurora + AES16 (pci)/ |
Re: Issues ...
If you have the nvidia control center installed, go in it and make to manage 3d settings, click on the program settings tab, add pro tools in it, and then set everything to off, and to high performance. That should set your video problem straight, for the meters and the counter.
Re: Issues ...
"My ego comes pre-shrunk" - Randy Thom |
If off isn't a value set the value to 0. It forces the card into high performance mode that you wouldn't be able to achieve if you did not install the nvidia control center.
Re: Issues ...
Did all that you explained. PT10 launch/close still takes a mighty long time. Occasional 9128 error. FIX: Close session, Delete DAE Pref folder & Avid folder in Roaming, empty Recycle Bin then load session. |
I love it . The only issue I have is my system will freeze up when I add a track or a pluggin while the music is playing , no problem if i stop playback first.
focusrite liquid saffire 56 ,digi rack 02/ presonus digimax 8, allen heath gl2432, mobo asus m4a88td-v evo/usb3, AMD 1075 sixcore corsair XMS3 ddr3 4g (x4) western digital 1tb hard drive 7200rpm(x 2), 680watt power supply no name, windows7 home premium 64 bit |
HELP!! PT10 Latency overcompensation places odub tracks 40ms early | peteage | FireWire & USB Audio Interfaces (Win) | 0 | 09-09-2013 04:11 PM |
PTHD 10: Early Adopters. Any 9000 Error Issues? | aboriginal | Windows | 2 | 11-03-2011 04:51 AM |
Questions for PT8 early adopters. | Frank Kruse | Post - Surround - Video | 8 | 01-04-2009 05:08 AM |
Free Plugins-For LATE adopters!! | klaatu | Pro Tools TDM Systems (Mac) | 13 | 03-14-2003 03:42 AM |
PT 6.0 Early Adopters - Happy? | Markk | Pro Tools TDM Systems (Mac) | 29 | 03-11-2003 11:30 AM |
