Old 06-13-2001, 11:49 AM
ragbor ragbor is offline
Default Can you put a stock 9600/350 processor in a 9600/200?
My two 9600s have slightly different motherboards in spite of their manufacturing dates being 6 months apart. Were there 'versions' of the 9600 excluding speed differences or were the motherboard configs native/restricted to use of their stock processor card? Wondering if I can swap my stock 200mhz for a stock 350mhz processor card. Anyone with info or experience? Thanks...
Old 06-13-2001, 01:31 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Can you put a stock 9600/350 processor in a 9600/200?
T-LAY is correct. I researched this a bit when I upgraded my 9600/350. I was able to use the 350 daughter card in my 8600/300. I wasn't aware of the 8600/250 working, but a check at www.everymac.com reveals that it also is based on the "Kansas" architecture like the 9600/300, 9600/350, and WGS 9650/350. I don't know of any other models that it would work on.
Bruce Paine
Hill City, Kansas
Administrator
Old 06-14-2001, 12:09 AM
eriqjaffe eriqjaffe is offline
You should be able to do that with no problem. Just be sure to reset the CUDA (the little red button on your motherboard) before you reboot the computer.
--Eriq
Old 06-14-2001, 12:58 AM
T-LAY T-LAY is offline
NOOOOOOOO !!!!!!!
[img]images/icons/frown.gif[/img]
The 350 MHz-Card is "Mach5"-CPU
aka 604r and has INLINE-Cache
running @ 2xCPU-Bus = 100 Mhz.
This Card will only fit into 8600/250 ->
9600/350.
older 9600 (604 & 604e -> max. 233 MHz) have "simple" 2nd Level-Cache running
@CPU-Bus = 45 - 50 MHz.
if you want to boost your 9600 for ProTools, better buy a G3-Upgrade
from "XLR8".
Old 06-14-2001, 10:29 AM
Thank you all for your feedback. I'm going to check that everymac.com site, Bruce. Wondering where you got your good info, T-LAY.
dual monitor card on stock 9600? robi3 Pro Tools TDM Systems (Mac) 1 07-25-2001 06:34 PM
Replacing stock 9600/350 (upgraded G3/400) video card Marco Migliari Pro Tools TDM Systems (Mac) 0 11-13-2000 06:51 AM
Dual Processor 9600 binaural General Discussion 2 06-30-2000 04:17 PM
processor upgrade for 9600 MP seromaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-26-2000 02:53 PM
installing G 3 processor into a 9600 bigtree Pro Tools TDM Systems (Mac) 5 05-20-2000 03:41 AM
