Multichannel plugins (eg DR-008)
I have added an instance of DR-008 to a stereo aux track. The DR-008 is configured for 4 stereo outputs and I can hear the first stereo output on the aux track. I added another 3 stereo aux tracks for the other 3 outputs on the DR-008. The problem is, when i try to configure the inputs on these aux tracks, i cant assign the outputs of the DR-008. The submenu "plug-in" is greyed out completely. Is there something else I need to do? Any help would be appreciated. Thanks PS. I am using the demo version of PT M-Powered while I wait for my order to arrive in the mail. Is this a limitation of the demo? |
Re: Multichannel plugins (eg DR-008)
You are not doing anything wrong. If I am correct, Pro Tools does support multi-outputs but not in the same way a VST host does. The DR008 currently only supports 2 outputs (ie a stereo channel) in Pro Tools. FXpansion will need to update the RTAS version to take advantage of Pro Tools' multi-channel support.
Pro Tools|24 Mix Plus 3 (6.4.1 cs4) G4 AGP Sawtooth with 1Ghz Sonnet Processor Upgrade 1.5 Gig of RAM. OSX 10.3.4 Command|8 |
PTLE8 will not show some of the multichannel plugins ... | Vadadi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-06-2009 10:47 AM |
No multichannel EQ? | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-23-2008 04:30 PM |
Can LE do Multichannel mixes. | JonHallur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2008 02:20 AM |
Any recommendations for a multichannel amp? | anodecathode | Pro Tools TDM Systems (Mac) | 11 | 06-06-2004 04:36 PM |
Multichannel panner in PT 5.1? | DigiTechSupt | Pro Tools TDM Systems (Mac) | 4 | 04-10-2002 11:42 AM |
