  #291
Old 03-20-2024, 05:32 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Default Re: MacOS Sonoma
I agree re: PT vs Logic - but Pro Tools won me over when they introduced the Eleven Rack and it's fantastic integration with PT - since deprecated sadly.
I have removed all plugins - trashed prefs - tried 3 different audio interfaces - rosetta on/off - PT either crashes when loading a session or plays for < 10 seconds and freezes.
I think the ancient (in tech terms) under-pinnings of Pro Tools are really coming home to roost.
I could wipe-and-reload my MBP and I may but I think it's time for me to move on/back to LPX.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #292
Old 03-20-2024, 06:08 AM
marianna's Avatar
marianna marianna is offline
Hi there....
I created a case and asked the head of the tech team to assign this asap.
Case # 04775201
They need to determine if it is PACE, macOS o PT related and how to help you. It would be good to get some crash reports and log files from the system so if they ask here is how to do that.
Pro Tools crash reports:
Pro Tools log files:
Lets give this a whirl before you jump ship.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #293
Old 03-20-2024, 07:51 AM
BCnSTL's Avatar
Thank you Marianna.
I have several crashlogs in the location indicated.
I've replied to the email. Glad to try to work through this.
My strong preference is a working, robust Pro Tools setup.
PT 2024.3 Native
  #294
Old 03-20-2024, 09:22 AM
ZoeMusic's Avatar
ZoeMusic ZoeMusic is offline
Originally Posted by peapodpost View Post
14.3 gave me a new bug with PT23.12. eucon 23.11. M2 studio.
fast scrolling up and down in the edit window crashes PT every so often (multiple times a day) - no error though, just force quit and gone.
console logs something about graphics dylibs.
i'll try deleting wavecaches and pt prefs tomorrow.
Originally Posted by JouluPam View Post
Hi all!
After upgrading to Pro Tools 2024.3 moving clips and fades around causes the transparency effects to flicker, along with the clips them selves. Very annoying. Anyone experiencing the same issue? Any help?
I'm on Sonoma 14.4. Didn't happen before 2024.3.
Thanks.
System Details:
MacBook Pro 16-inch, Nov 2023
M3 Max, 16 (12/4) Core CPU
40 Core GPU, 128 GB RAM
macOS 14 (Sonoma)
Pro Tools Studio
Perpetual License
w/Update & Support Plan
For those of you who are having flickering and scrolling issues you might want to make sure your display refresh rate is set to a fixed rate and not variable. I have run into these kinds of weird issue in the past with Pro Tools and that fixed the problem for me. I have it set to 120 Hertz and all is good now. You could give it a go.
Pro Tools Studio 2024.3 | Studio One Pro 6.6 | Logic Pro 10.8.1 | Dolby Atmos Render 5.2 & Album Assembler 1.3 | RME BabyFace Pro FS | UA Native Plugins & Sphere LX | SSL UC1 | 2023 Mac Studio M2 Max 12 Core CPU 38 Core GPU | MacOs 13.5.0 | Genelec 8020D & Yamaha MSP10 | Korg Kronos LS | Sonarworks Sound ID | Beyerdynamic DT 1990 Pro | DT 880 PRO | DT 770 Pro | etc.
  #295
Old 03-20-2024, 09:33 AM
marianna's Avatar
Nice suggestions Zoe! Had not thought of that.
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
  #296
Old 03-20-2024, 01:28 PM
BCnSTL's Avatar
Originally Posted by marianna View Post
Hi there....
Marianna
Again - I very much appreciate the effort to help me.
The response says I need to install a supported OS.
Reverting to 14.3 on Apple Silicon is a massive PITA.
No - you can't do it via Time Machine - try it.
Using recovery mode to reinstall the OS will reinstall, yes, 14.4.
This is not worth the effort.
I'm going to mess around with LPX and who knows - maybe Apple or AVID or PACE will release a fix before I get too far down that road.
As it stands I can't even get PT working enough to export anything.
PT 2024.3 Native
  #297
Old 03-21-2024, 02:45 AM
ralphonz ralphonz is offline
Thanks, good suggestion but my refresh rate is fixed at 60 hertz. HDR is also off. The flickering only happens on clips with transparency though.
  #298
Old 03-21-2024, 10:14 AM
ZoeMusic's Avatar
Quick question for you guys who are on Sonoma. How are your plugins working? I have not seen many plugins manufactures who are giving the go ahead. Also can you list the Sonoma version you are on with your answer?
Thanks in advance!
  #299
Old 03-22-2024, 02:11 AM
Thanks in advance!
Mine all seem to be working great. UAD, Waves, PA, Liquid sonics, Softube, iZotope and a boatload of others. No complaints so far...
  #300
Old 03-22-2024, 02:14 AM
mattrixx mattrixx is offline
Same here. M1 Ultra. You running an M1 series also?
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
macOS 12.4? off the wall macOS 36 06-06-2022 11:50 AM
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur newstrings Pro Tools HDX & HD Native Systems (Mac) 6 01-15-2022 11:48 PM
macOS 11.6.2? off the wall macOS 9 12-19-2021 08:46 AM
Macos big sur nesseldigital Pro Tools 2020 2 12-27-2020 04:49 PM
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
