DAE ERROR 9060 WAS ENCOUNTERED
HELLO, just posting that i encountered an error with the new upgrade. I installed it on 7/19/ and i encounterd the error on 7/20/. I was using vocalign(a/s)and then the error came up. I hit the ok and then i tryed to playback my tracks and the dae error kept on coming up and wouldn't let me playback my tracks, so i saved my session,quit pt, and restarted my mac and everything has been ok for now but should i reinstall my old pt 5.1.1 until the bugs are fix because i don't want this to happen when i have clients.
Re: DAE ERROR 9060 WAS ENCOUNTERED
I got 9060 error too!!
But I ran Norton Disk Doctor, nothings' wrong with my disk. Seems like the 32 track beta is giving some problems? I am using G4 400, 1Gb Ram, 1 ATA HDD for system disk, 2 ATA HDD for Audio disk and 1 ATA HDD for Video. (I ripped off the DVD ROM to install the 4th ATA drive) And everything ran smoothly in 5.1.1 never encountered 9060 errors before until I installed the beta. When I test out a 32 tracks session, everything was okay. BUT, the session that I encountered the 9060 have less than 16 audio tracks, 4 MIDI tracks, 1 stereo AUX tracks and 1 stereo Master track and 1 movie track. And the session is about 25 minutes long. Digi, is it a known error with the beta? (thats' why its called beta, I supposed) Thanks and Regards, [Charles]
:: TWO ROOMS pte ltd :: Audio Post Production :: for Film / TV / Radio / Internet / Multimedia :: www.tworooms.com |
hi,
i also have the -9060 DAE error.. The session was first made in 5.1.1, never had this kind of problem before.. I installed 5.2.1 beta on thursday and everything was really great until i did something i usually do : record a sound from dat. stop. then record another sound and rename the first sound during recording of the second one..bang : -9060 error. and after that, i can't even play smoothly without -9060 error. The bug is still there after reinstalling 5.1.1 if i don't delete the digisetup file. I think it's a bug cause i could reproduce it. Hope a fix will come soon, i was so happy to begin to edit a movie with 32 tracks.. Mik |
Just want to chime in on the 9060 error.
I got some too last night. Similar situation- separating and copying (option+drag) a region while PT was playing. After the 9060 error, I could do nothing but save, quite PT and restart PT. All was fine until I did the same thing again. Sounds like a bug, Digi. put it on the list! |
I was getting the -9060 and -9123 errors. Went back to 5.1.1 and everything was dandy, like it's been for the past year and a half.
I then tried it again. I trashed the PT LE/DAE 5.1.1 preferences, replaced the PT LE/DAE 5.1.1 apps with the new beta then changed the new 5.2.1 DAE buffer size to 4 instead of 2 -rebooted and actually left the stock memory allocation in the new 5.2.1 PT LE/DAE beta. It's working great now. Have yet to get into anything REALLY heavy with it. Keep you posted. Chris 001 G4 867 Mac OS 9.2 640 MB RAM Pluggo 3.0, ChannelStrip 1.2 & Waves 3.2.1 Korg Oasys and SampleCell 2 Plus PCI cards
Genuinely, Chris |
OK I set DAE and PT to the stock memory allocation settings and couldn't even open DAE with the buffer on 4. The stock allocation is something like 2 MB over what DAE says it will need for the 4 buffer setting.
I reset my DAE mem to 100 and now I'm fine. I still have the PT mem on the stock setting, so I'll see how that goes. :::UPDATE::: no better. I still can't rename a region, or do pretty much ANYTHING while PT is playing. |
Regards, [Charles]
One other thing obout the 9060 error thing:
IT ONLY HAPPENS WHEN YOU ARE IN SDII SESSIONS, it doesen't happens in a Aiff session, it works perfect, its a thing with the "rename disk file name" pablo |
DAE error 9060 was encountered | chirotay | Pro Tools M-Powered (Win) | 4 | 10-02-2013 05:06 PM |
DAE error - 9060 was encountered. Help???? | time808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-24-2004 11:47 AM |
DEA error 9060 was encountered. | BOMBA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-26-2002 10:19 PM |
DAE Error-9060 Was Encountered | recordingguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-28-2002 09:46 PM |
DAE error - 9060 encountered | txchain | Digidesign Hardware & Software | 1 | 04-28-2002 07:07 PM |
