Mbox 2 with Macbook Pro 15" i7 not working
Hello,
I've recently installed Pro Tools LE 8 on my 15-inch: 2.66GHz macbook pro which is running on OS X 10.6.3. Also, after several frustrating minutes, I found what I believed to be the correct updates (8.0.3 Update for Mac OS X and Pro Tools LE 8.0.3cs2 Update for Mac). Also, I read some forums that suggested I plug in the Mbox 2's usb cable into the USB slot closest to me on my macbook. After I attempted to open Pro Tools from the dock, the loading screen came up, loaded all of the plugins, and then when the Open Session window should have appeared, it just froze without any window even open. I checked in the Force Quit Applications window on my macbook, and surely enough, Pro Tools Le was Not Responding. I've tried again and again several times, but the same thing keeps on happening. Is there anybody who may possibly know what's causing this to happen, and what I can do to fix this problem? Thanks. |
Re: Mbox 2 with Macbook Pro 15" i7 not working
seems like alot of people have problems with the usb mbox2 series...but not with the firewire series
I have the same problem with an Mbox 2 Mini. didnt have this problem with my previous Mac (tiger) and Pro Tools LE 7.3.1
Now i got this new Mac and new Pro Tools LE 8. but it's sad that i cannot use it. Would be nice to learn how to fix this problem. Thanks |
Macbook Pro 17'' i7 with Mbox 2 Pro (firewire) is not working either.
Is the new MacBook Pro 13 also affected by the problem with Mbox2?
regards Wasserwerk PS. This is my first post so hello and welcome! |
goto post logic 9/pt le 8=15" mbpro i7 2.66- 10.6.3 sleopard......your answerr is there
its the driver goto this thread....miine works after doing it |
I'm not sure how exactly to do this, but you may want to revert back to the Mac OS X 10.6.2 because 10.6.3 is still in testing by Avid.
There are a lot of PT8 users that say that they haven't had any problems with 10.6.3, but some say they have so I'd give that a try. -Zooce |
barry1, can you please give me a link to that post? I tried to use the forum search to find it, but I was unable to find it.
I just today got my refund from Avid for the PT8LE upgrade I purchased.
The tech support people I spoke to said a fix was imminent but couldn't say what that meant exactly - a month, two, more ... There are some tricks you can try to make it work in the interim but it's really sort of half-assed, imho. I didn't necessarily want to return the software but that was the only way I could ensure my 30 days of tech support would happen when I was actually able to use the product. |
logic 9/pt le 8 = 15" mbpro i7 2.66- 10.6.3 sleopard is the post in duc and it lead to apple discussion post... go to library>audio>Midi Drivers and remove the DigiDioMidiDriver.plugin file....http://discussions.apple.com/thread....readID=1650172
MacBook Pro 13" i5 last non Retina working well with PT11 | VRW | Pro Tools 11 | 0 | 03-15-2014 08:33 AM |
MBox "launch control panel" button not working again with the latest driver | Zarabozo | Windows | 0 | 10-26-2012 12:01 AM |
HD Native not working on new MacBook Pro 17" Quad-Core, Magma EB1H | kevinmac | Pro Tools HDX & HD Native Systems (Mac) | 4 | 03-08-2011 10:42 PM |
Mbox "3" on a dated Macbook? | bfx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-01-2010 01:02 AM |
Mbox 2 mini not working with macbook | Luke K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2009 01:12 AM |
