Old 06-06-2004, 02:16 PM
Ralph K Ralph K is offline
Default Can I assign one track to multi outputs (digi002r)
thx in advance.
my songs website
Old 06-06-2004, 03:00 PM
Default Re: Can I assign one track to multi outputs (digi002r)
Yes.. use the Start modifier key.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-06-2004, 03:02 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
You can do this by holding down the Start key on the PC and while making your additional output selection. After you have assigned the additional outputs he should see a + displayed next to the original output assignments.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 06-06-2004, 04:06 PM
nukmusic nukmusic is offline
Say Whattttttt I asked about doing this a for the Master Fader output and the replies were:
"nope"
I wanted to add another steroe out for headphone mix because the main and Mon out on my 001 is use by 2 sets of speakers. I used 2 y-cables instead.
Will the above work on the Master. I'll try later, cause I'm on the labtop.
Docta'J
Download free music at
http://www.nukmusic.com
nEVER uNDERESTIMATE kNOWLEDGE
Old 06-06-2004, 05:10 PM
A Master Fader by definition can't control more than what it's the master of.. so you can't assign multiple outputs to a Master Fader.. otherwise it wouldn't be a Master Fader - it would be a Sub-Master Fader... and then we'd need to have additional Master Master Faders.
Rail
Platinum Samples
Old 06-06-2004, 06:52 PM
Very True. So the old y-cables should stay in play? Thanks Rail.
Docta'J
Old 06-06-2004, 07:54 PM
Chris Cavell Chris Cavell is offline
Just create two outputs for all your tracks except the master fader...you'll need two of those: one for each output.
Cavell Studios
Assign outputs odd problem PTPerson ProControl, Control|24, Command|8 0 11-17-2011 12:30 AM
Apogee Duet outputs better sounding than Digi002R outputs? Pasz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 03:19 AM
How to assign stereo recordings to multi-channel? hkju2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2007 11:13 AM
how to assign additional outputs? musicmixer04 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-12-2006 02:09 AM
Assign multiple outputs from a Midi Track Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2003 06:17 PM
