Old 04-17-2018, 08:39 AM
Mischdepp Mischdepp is offline
Default PT unexpectedly quits - Session corrupted after relaunch
I have recently updated a clients HD Native system to Pro Tools 2018.3
I did a clean install of OS X 10.12.6 on a new SSD and then installed the drivers, Pro tools, plug-ins etc. (previous system was 10.9.5 Mavericks and PT 12.4).
Computer is a Mac Pro 5.1 with 24GB of RAM.
My Problem is that when I open sessions they load fine I can press play and stop one or two times but then the spinball appears and I have to force quit PT.
After restarting the Mac and rebooting Pro Tools the session does not load at all but brings the spinball back immediately. The only way around is creating a new session and importing all the tracks from the corrupt one.
The new session will then work fine for some hours but then the spinball reappears out of the blue and I have to repeat the procedure (new session, import tracks from corrupted session).
This is annoying and I also end up with new folders for each new session and audio located in several audio file folders.
I first suspected auto save to be the cause of my trouble but PT continues to quit after disabling auto save.
Video engine is off because I use VideoSlave.
No VI's just a couple of audio and aux tracks for voiceover recording of tv documentaries.
No WiFi and the problem occurs on internal and external drives.
S3 connected via Eucon (eucontrol 18.3.0.244 and firmware 1.2.0.131
Any ideas for a cure
MacMini 8,1/ 32GB Ram/ OSX10.15.7/ ProTools Ultimate 2022.10 + 2021.12/ Focusrite Red4Pre/ BM Decklink Studio 2/ Avid S3
Old 04-17-2018, 09:12 AM
ibbod0 ibbod0 is offline
Default Re: PT unexpectedly quits - Session corrupted after relaunch
if you hold shift while opening a session, it makes all plugins inactive. can you open the corrupt sessions this way? if so, it may be an issue with a certain plugin or combinations of plugins going by my past experience.
Old 04-18-2018, 07:03 AM
Thanks for the quick reply.
I think I found the problem - it seems to be the VisLM plug in from Nugen Audio.
When I close the plug in window everything works fine.
Just contacted Nugen support.
Old 04-18-2018, 10:40 AM
climber climber is offline
So many of these kinds of issues are plugin related.
Just sayin....
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Pro Tools LE 8.01 cs1 quits, session corrupted. zOap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2010 03:25 PM
PT "unexpectedly quits" whenever I load session... Amo Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2005 04:14 AM
PT LE Unexpectedly Quits -for 1specific session charliethree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-14-2004 04:26 PM
PT6.1 unexpectedly quits when closing session Skaberlakestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-02-2003 06:26 AM
6.0.2 - RACK - First Session = Unexpectedly Quits propynyl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-06-2003 02:48 PM
