Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 09-25-2014, 11:29 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default HDX and HD I/O.
Here's the issue I have a question about. I purchased an HDX card I haven't installed yet (still using my HD4 system) , but I need to know if I use my Antelope Trinity /M10 combo (word clock), do I need to use the loop sync on my HD I/O's while clocking with Trinity/M10 combo if I'm using the same digi-link port on the HDX card? I know I don't need the loop sync if I use one digi-link port per HD I/O if i use external clocking, the question is if I use 2 HD I/O's per digi-link port on the HDX card.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 09-25-2014, 05:46 PM
Default Re: HDX and HD I/O.
Now you have me wondering. I was under the impression that Loop Sync should always be connected with multiple HD interfaces(running an HD IO and a 192 here).
Old 09-25-2014, 07:14 PM
Craig F Craig F is offline
In systems I've seen that did not utilize Loop Sync I have seen the interfaces get out of sync with themselves/the Digi Link cable and go into mute mode or random clicks and pops
Thank you,
Craig
Old 09-26-2014, 10:52 AM
abc1mce2's Avatar
I don't run a pro studio but I do use my system alot and as far as I recall I haven't had the issues your referring to. As of right now on my HD4 system I have 2 Avid HD I/O's and each one is connected to a separate HD core and accel card. As said before I am use the Antelope Trinity/M10 combo for clocking.
When I finally start using my HDX card both machines will be connected to a single HDX card (til I buy 2 second card) and possibly to the same digi-link port so I can (considering) use the 2 digi-link port for the Digigrid DLS system. This is the reason I'm asking if anybody here has any experience using 2 HD I/O's on the same digi-link port without loop sync, but using external clocking.
I guess the best solution is just to try it with loop sync.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 09-26-2014, 01:34 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
Unless your running a WC cable to each HD I/O from the Trinity then you will need to use loop sync.
I have 2 192's connected to one port on my HD|Native card clocked to a antelope clock and after all the research I did I settled on loop sync instead of running separate WC cables to each I/O unit.
I just feel most comfortable that way and have never had any pops/clicks or any problems with sync.
But theoretically as long as ALL I/O units are getting the same clock signal you should be fine.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 09-28-2014, 10:34 AM
abc1mce2's Avatar
Thank you. I think just to be safe I'll added the loop sync and go from there.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
