NI updates dropping RTAS support
Just a note to all that use Native Instruments stuff. In the process of updating their software to work with the new controller keyboard coming with Komplete 10 NI is dropping RTAS support for some of their stuff. Right now Kontakt 5, Battery 4 and possibly Reaktor 5 with the latest updates just out this month have dropped RTAS support. I have the feeling that more NI product will do the same.
So message to all that sue NI product: Beware the updates or you may/will lose RTAS capability. |
Re: NI updates dropping RTAS support
Thanks
This is a good news update:
When I do drums in a session I routinely go back to PT10.3.9 so I can use BFD2 and get individual audio outputs for each drum which you can't do in PT11 hosting BFD2 inside MB7-2 or Patchwork; if you can I haven't figured that out. Since I had PT10 fired up I created a blank session and put in a couple of instances of Kontakt. As we all know PT10 uses both RTAS and aax. Kontakt instantiated and worked perfectly. Saved the session and quit PT. Looked in the plugins folder in the Digidesign folder and noticed I still had the .dpm/RTAS version of K5. And of course in the Avid plugins folder I had the aax version of K5. Moved the aax version to the unused plugins folder and re-opened the session and K5 worked perfectly with the RTAS version. Put the aax version back in the used plugins folder and moved the .dpm/RTAS version to the unused plugins folder (PT shut down of course). Re-opened PT and the session and everything ran as it should with PT picking up K5. Apparently when doing the update it does NOT wipe out the existing RTAS version of the plugin. This is good news. |
Support Updates? | billunatic | Avid Scorch (iOS) Forum | 7 | 09-12-2012 02:38 AM |
Some questions about what dropping legacy hardware support from PT11 actually means | nigelpry | Pro Tools 10 | 5 | 12-12-2011 09:06 AM |
Avid Dropping RTAS support?! | alw4416 | Pro Tools 10 | 7 | 11-14-2011 07:24 PM |
Interesting! Korg dropping dongle support for Legacy collection. | crizdee | Pro Tools TDM Systems (Mac) | 9 | 11-09-2009 02:04 PM |
is DIGI really dropping Mac Support? | cliepe12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-10-2004 10:25 PM |
