Old 10-25-2006, 03:38 PM
SF_JTRIX SF_JTRIX is offline
Default Mbox 2 Pro connection problems
Hello everyone, I'm new to the whole protools game, just picked up an Mbox 2 Pro, but I'm having trouble connecting the Hardware to my computer (or at least I think)
I followed all the directions from the start-up manual, and I installed Pro Tools 7.2 in my computer, but when I try and record I don't get a signal into ProTools, but I get a signal into my Mbox 2, and no audio coming out of my monitors.
Do I have to change any settings in my computer to run the Mbox?
I'm running a Powerbook 12", 1.25Ghz, 512 Ram
If anyone has any ideas as to why it is not working, please let me know, I want to get started on using Pro Tools ASAP!
Thanks,
DJ J-TRIX
Old 10-25-2006, 07:35 PM
len branville len branville is offline
Default Re: Mbox 2 Pro connection problems
Welcome Trix,
You could try and go to "setups" menu then "I/O" and then select "default" in both input and output tabs. Make sure that your monitor control (and input controls) are adjusted accordingly on the Mbox Pro interface (and that the mic and/or instrument buttons are pushed in/out depending on what your recording). Lastly, have you record enabled a track to monitor said input (just thoughts).
len
www.labranville.com
Old 10-26-2006, 04:46 AM
Will Russell's Avatar
Will Russell Will Russell is offline
The MBox2Pro requires ProTools LE 7.1.2 only. Any other version of PT will NOT work.
ProTools 7.2 is for TDM systems only.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.13.6, PT2018.12, HDX, D-Command
Retina 5k iMac OS 10.14.2, PT2018.12, MBox3
Retina MacBook Pro OS 10.14.2, PT2018.12
Old 10-26-2006, 02:14 PM
I'm sorry, I am running 7.1.2, and I'm running OS X 10.4.8, should I downgrade my OS?
Old 10-26-2006, 06:17 PM
I found this statement from Digi on the compatibility page...
"Although there are no known issues at this time, Mac OS X 10.4.8 is not yet officially qualified with any Digidesign products".
I'm running 10.4.6 and everything seems to be okay.. but if your not experiencing any problems.. downgrading the OS kinda sucks.
Enjoy,
leonard
www.labranville.com
Old 10-27-2006, 04:35 PM
Wait!
Don't downgrade your OS.
As you probably have noticed, Digi approved 10.4.8
Good luck!
len
MBox Pro 3rd Gen Connection Problems TheSmackPanda FireWire and USB Audio Interfaces (Win) 6 05-16-2013 08:54 PM
*Fixed* my Noise and connection problems with MBox Pro2 hardhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-09-2010 02:34 PM
Problems connection MBox 2 to GarageBand cedilla Pro Tools M-Powered (Mac) 2 06-26-2009 10:17 PM
Mbox2 Connection Problems redshifted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-09-2007 06:06 PM
888 connection problems? jim2step Pro Tools TDM Systems (Mac) 0 08-16-2004 12:29 AM
