Re: Digidesign Digital 192 I/O internal 50 pin cables
Try putting the digital cards in Bays 1 and 2 in the Analog Chassis. Maybe this works. As the digital Cards are in Digital192 as well in Bays 1 and 2, maybe the interface needs to see a card in the first bays.
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
It woks!!!! It really works!!!! Thanks a lot!
Mac Pro mid 2012 3,46 GHz 6-Core 48 GB HD Native PCI, 192 I/O, 192 Digital I/O, SSL Alfa Link Pro Tools 10HD, 12.5, Logic Pro X 10.2.2 |
So, I recently bought a used 192 analog I/O w/ 2 Digital cards for my PT 9 HD system, so that I could step away from using the X-HD cards on my 2 Apogee Rosetta's, and use the 192 ADAT optical ports as the I/O for the Rosettas.
For WEEKS now I have been tearing my hair out because I could not get Pro Tools to recognize the 192. The digital cards were in slots 3+4, which everyone said is where they should be. The interface passed Digitest, and it saw 16 channels of I/O, but when it came time to boot up Pro Tools - No Interface Found, every time. The guy who sold me the 192 even sent me a second one, thinking the first one was damaged somehow! I just now stumbled on this thread, swapped the cards into slots 1+2, and lo and behold, the system booted right up. Thank you! Now what I'm wondering is - part of the reason I wanted to get the 192 going is so I could eventually add a couple of analog I/O cards for more I/O options. But are you saying that I can't have 16 channels of digital I/O going *in addition* to 8 more channels of analog I/O, that I can only have 16 channels total at any one time...? Another thing I noticed is that in Hardware Setup it says I am connected to a 192 Digital I/O. Why is that? Because it's seeing a digital card first...? Anyway, this is great. Major mystery solved. Thanks! - Steve |
Hey Steve-
Glad it worked out! However, I *did* mention that to you over on GS :) http://www.gearslutz.com/board/9497642-post21.html
________________________ www.PlethoraTone.com PlethoraTone Studio Video Tour At PlethoraTone: Mac Mini M1, Avid Carbon, PSP, Waves Mercury, UAD, Kush, Slate Digital, PA, Melodyne, Antares, Audioease, SoundToys |
Thanks, I did read your post! I totally appreciate all tips and feedback. And I know that in the 192 Digital the cards go in slots 1 + 2. But this is an regular old analog 192, not Digital. From everything I read and heard the cards are supposed to go in 3+4. But apparently not when there are no analog cards. At least in these couple of weird cases. Anyway, should have tried this swap a lot earlier in the process... Thanks!
#16
To answer your question re: amount of IO, any Digi device is only capable of 16-channels per box. You can link a 2nd 192 to this one for 32, but that is the max amount the core card can see. 32 total @ 16 per device and 2 devices.
You can use multiple outputs, which is what we do, i.e. AES outs 1/2 are mirrored on analog 1/2, etc.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#17
I am running an older HD system but it pertains to the i/o config of the Blue Digi 192. I have all four slots filled. One AD, one DA and two AES cards. I can't seem to get the second AES card to function correctly. I know I an only have a max of 24 i/o working which I can do. The AES card in the 3rd slot is being used for digital reverbs so it is a 16ch digital i/o. I can still output 8 analog stems without any problem. This is a mix setup. Here's what I'd also like to do and can't seem to. I'd like to use the 2nd AES card (4th slot) to input 8 AES signals from a separate converter. In that particular session I am not using the 1st AES card even though it's i/o is part of the general setup. The analog cards are always in the i/o setup but I can make them "none" but the digital cards won't play nice with each other. I have a second non-Digi interface with an HD card which shows up as a 192. I have that connected to my 1st Accel card, not to the digi-expansion on the Digi 192. Will changing this help? Thanks for you time with this. If I don't have to purchase another 192 I'd rather not.
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
#18
Digidesign/Avid have decided that one box has 16 i/o and that's it. Technically there is no reason why there would not be a single 32 i/o box. 3rd party vendors such as Apogee have different solutions, but that's another story.
#19
Can you help me with this I/O setup config? Shouldn't I be able to access the inputs from the 2nd AES card (slot 4) even though I have an AES card in slot 3 which is configured as Bus I/Os.
#20
If you have a 192-DIGITAL you can use two digital cards just the way you want to. It is 16 in 16 out box and it cannot be modified.
If you have a 192-ANALOG you can have more i/o possibilities that you can tweak in the PT hardware setup. But it is just the same, you can only use 16 ins and 16 outs at any time.
Digidesign Cables + Apogee 16x = Don't fit? | BasketCase | Pro Tools TDM Systems (Mac) | 2 | 02-28-2013 10:45 AM |
FS: High Quality Digital XLR cables | Captain Audio | Buy & Sell | 0 | 05-22-2012 11:11 AM |
Internal SCSI Cables | DocDolby | Pro Tools TDM Systems (Mac) | 2 | 06-02-2008 02:43 PM |
please explain... digital cables (s/pdif) | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-23-2005 11:03 PM |
Cables for Internal SCSI | goherbal | Storage Subsystems | 3 | 12-30-1999 12:18 AM |
