#31
Re: M-Powered vs. LE
...And what about the USB iLok key?
Does that mean M-Powered PT can be used without the M-Audio hardware connected to PC, only having the USB key attatched? Enabling mobile editing at PT, without carrying the interface about? |
#32
no...
according to digi m-audio hardware must be connected to open software, just like in PTLE. |
#33
Shame
#34
where u gettin this info? im not seeing it on either maudio or digidesign websites |
#35
I got my 1814 the other day and have played with it a bit - including opening it up and looking at the silicon that they use.
First, to clear the air - the 1814 has unbalanced inputs, the outputs are balanced. Feature wise, there are a lot of issues to look at. 1. People argue about +4 and -10 operation, but the bottom line is that with +4, most equipment ends up going through another cheap opamp. In general, you want to minimize your signal path, so for the "low end" gear we most have, the general concensus is to stick to -10. 2. They same can hold true for balanced, unbalanced - I would rather use a good transformer than count on a cheap opamp to do the conversion to balanced. Bottom line is that the A/D's used are unbalanced in - so it's going to go unbalanced somewhere - use good cables. Regarding the chips - this thing is bus powered, so you only have +5V to work with (Since the mbox uses the same power - I bet it has the same type of architecture). The opamnps are National LMV722 - 10MHz low noise, generic stuff. The converters are all AKM - the same brand that focusrite uses in the Liquid Channel (on the 1814 Channel 1/2 are the AK5385 (192kHz) the others are AK5381) The mic pre looks to be made with a typical Mackie configuration - 4560 opamps driving the LMV722. I don't know what the mbox or 002R "focusrite" pre's are - but they always sounded harsh and one dimensional to me compared to just about anything. I have never opened up my 002R, and won't now - it's going up for sale shortly. But, chances are, with higher voltages available due to the plug-in power supply, it might use higher voltage opamps, which would give higher headroom. But the A/D's can't take any higher signal level, most all of them on the market these days are +5V operation anyway - so if the signal is going to be down at that level anyway, then why add another opamp to boost the signal level in between - again, go for the cleanest signal path. There are basically 2 A/D companies that are used for general purpose audio - Crystal and AKM, so I don't expect there to be that much difference in the under $1k for 2 channels group. Even my Frontier Tango uses Crystal chips. And by the way, the AD192 converter for the Presonus Eureka looks just like the m-audio stuff - runs on 5V, but has slightly better opamps (TLO series) The only thing I might consider doing is swapping the opamps for OPA2353's or TLO series stuff, but at 44MHz, the Burr Brown's could end up with some stability problems. I feel, in the end, it comes down to your front end - get good mics and good pre's. Bottom line, compared to mbox - better latency, more portable, and more inputs. Compared to 002R - possibly some tradeoff in quality that may or may not be noticeable - but a heck of a lot smaller for on the go editing. |
#36
M-Powered 8 Essential -> M-Powered 8 Upgrade | Snowblind | Pro Tools SE and Essential (Win) | 2 | 08-09-2011 07:05 AM |
mac osx, m powered fast track, pro tools m powered | singdance6 | Pro Tools M-Powered (Mac) | 2 | 12-22-2010 09:24 AM |
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? | jeremiah0812 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-19-2010 10:10 AM |
PT M-Powered with FW400 bus powered audio drive? | bruceup | Pro Tools M-Powered (Mac) | 5 | 07-06-2006 01:32 PM |
bus powered interface + bus powered enclosure ? | technician | Pro Tools M-Powered (Mac) | 0 | 03-20-2006 05:34 AM |
