Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-06-2021, 07:49 AM
JMMPROD JMMPROD is offline
Default Scarlet 8i6 PT12 stereo guitar track
hi new here not sure if this is right place to ask for help with PT 12 and scarlet 8i6 interface?
i have done this a million times before with my old PT 8 and my 2 chanel M box. I want to record a stereo guitar using a mono input 1 preamp and cant seem to make a stereo session track record in stereo without making an AUX mono input and bussing to a sterio track, with my old MBOX i just used mono preamp input and could record a stereo or mono guitar track with ease. with the scarlet and software to assign input and outputs cant seem to record a stereo guitar track using a mono input source??? please anyone know
Thanks!
Old 03-06-2021, 01:46 PM
Default Re: Scarlet 8i6 PT12 stereo guitar track
This probably belongs in the Getting Started section. Having said that, you're likely doing it wrong. You record a mono source to a mono audio track and a stereo source to a stereo audio track. Of course, to record a stereo signal(of any kind) it takes 2 inputs/preamps. What exactly is your guitar source that you are referring to as "stereo"? If it actually is stereo(like the output of a Line 6 Helix), then you need to take 2 signals(left and right) from that source and connect them to 2 inputs of your interface. Then create a stereo audio track and select the proper PAIR of inputs. If that pair appears to not be available, open Setup>IO and select the INPUT tab and see what input paths are showing. It might be as simple as hitting the DEFAULT button, or adding the proper path manually(maybe watch some youtube tutorials on how to customize the IO setup). If this doesn't help, come back with complete details on everything and every connection
Change a track from mono to stereo in PT12 jamestr12 Pro Tools 12 11 04-14-2017 05:13 PM
Getting A Good Guitar Sound in PT12 johnbarnesiii Pro Tools 12 47 08-08-2016 03:51 PM
Dragging non interleaved stereo clips to stereo track changes pan [SOLVED] dalonso66 Pro Tools 11 0 06-02-2016 10:03 AM
Mono vs Stereo Aux Track For Guitar In PT 10 rockguitarist1255 Pro Tools 10 4 11-16-2012 08:03 PM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
