Anyone else seeing this problem with Kontakt
Using Kontakt to play the Akoustik piano library and getting this problem when i press start and stop on PT. I get this digital blip when i press start then when i press stop again i get a blip and the meter goes up to full-bore... http://www.youtube.com/watch?v=XcwOAdqRpb0 Chris
Re: Anyone else seeing this problem with Kontakt
i had this problem on LE...
Are you using Kontakt 4 and Snow Leopard? turned out some of the library patches were outdated... If we have the same problem, then: Go to the Akoustik Piano Library Folder and check the when the Library Folder has been created. If it's created July 29th 2005 or earlier, you need to update the Akoustik Piano patches to the latest version 1.1.3... I may add that i can't remember if this actually fixed the problem or not (switched to HD shortly after this) but this is at least what NI recommended i'd do - so worth trying!
www.olafurarnalds.com |
Hi, Thanks for the info! yes my Akoustik piano says version 1.1.3.001 and dates 11th August 2009 I have run service centre to update everything! Though this library was installed from Komplete 4 DVD's March 2007, but i think there has been some library patches!! Can't say i'm a big fan of having the pianos and organ as part of the Kontakt sampler, i preferred them as separate instruments Chris
I can agree with you there...
ProTools Le 8.0.5 and Kontakt 5 Problem | megasound88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-25-2012 02:18 PM |
Kontakt 4 Problem | Becharax | Virtual Instruments | 8 | 08-12-2010 05:16 PM |
problem with kontakt!!! | baek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-08-2006 02:51 PM |
Kontakt velocity problem | david_aka_mike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-02-2006 12:38 PM |
Kontakt Problem--CPU Overload? | nipk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-18-2004 09:19 AM |
