Old 04-18-2019, 01:41 AM
massimosammi massimosammi is offline
Default MIDI Editor in different Spaces on Mac
Hi there,
I would need help in my workflow with the MIDi editor.
I have two displays - the main one where I use the edit window, and where I switch to the mix window on a different space/desktop of this display, shifting between those either with the Mac shortcut, or with cmd+=, which switches between those two spaces.
I also use a bigger secondary display on the wall that I like for the video.
Right now, every time I double click on a MIDI clip the MIDI editor window opens up in the secondary display.
First of all, I’d like to make sure that the MIDI editor only opens in the primary display, leaving the secondary display with the picture visible.
Then, I’d like to move the MIDI editor to a separate spaces, like I did for the Mix window, and switch back and forth between spaces.
I selected the red square to make sure that it won’t duplicate a second MIDI editor window if I double click on a different MIDI clip. It works if I’m in the same space/desktop of the Edit window. As soon as I move the MIDI editor to a different space/desktop of the main display, and go back to the Edit window and click on a different clip, Protools opens a new MIDI editor which is what I’m trying to avoid.
Is there any smart way to avoid the duplication of the MIDI editor? I’m also fine with not double clicking the MIDI clip and using the Mac shortcut to get to the editor in a different space.
Is there a way to automatically populate the MIDI editor based on what was selected in the Edit window?
Thanks in advance!
Multiple Desktops/Spaces on Mac and MIDI Editor massi75 Pro Tools 2018 1 01-02-2019 05:20 AM
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
Can anyone clarify 1) Midi Track Sizing, and 2) color coding Midi Editor Infiltrator Pro Tools 9 5 01-10-2011 07:53 AM
Can you trim MIDI regions from inside the MIDI editor window? emspace Pro Tools M-Powered (Mac) 0 07-06-2010 12:13 PM
Calling all that write/program midi drums by hand in the Pro Tools midi editor. Mikey Ace Virtual Instruments 2 10-05-2008 07:14 PM
