Old 02-20-2019, 04:59 PM
lucidlife lucidlife is offline
Default Tracks not showing up in D control
Just started using it, and for some reason the tracks aren't showing up on the fader section. 2 channels say D- control on the unit.
I'm reading the guide now, but I'm not sure where to start.
We are using PT hd 2011 on a mac system OS X 10.10.5
Cheers.
Old 02-21-2019, 06:49 AM
its2loud its2loud is offline
Default Re: Tracks not showing up in D control
Did you enable the console in the periphials section of Pro Tools?
Old 02-28-2019, 03:30 AM
andrej770 andrej770 is offline
If it says D-Control on the two channel it means the board is offline mode. First, you must have a main console section of the D-Control to use the D-Control control surface. The Fader units cannot be used alone even though they show up in Pro Tools. Secondly, it only shows D-Control on the fader and main units when you are NOT in an active session in Pro Tools because (of course) this is a control service only for Pro Tools even though you can use the monitoring section to hear any sounds input into the XMON.
I hope this helps. Feel free to PM me if you need any additional help.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
Showing the needle on all tracks GtrDude Pro Tools TDM Systems (Win) 7 06-29-2011 08:25 AM
Imported tracks not showing regions grafic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-18-2009 06:16 AM
PT 8 with MPTK1 only showing 48 tracks MWP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-10-2009 11:13 AM
tracks not showing full audio JR1 Pro Tools TDM Systems (Mac) 1 10-26-2000 06:16 AM
Regions not showing in audio tracks rustyherzog Pro Tools TDM Systems (Mac) 1 10-03-2000 06:01 AM
