Old 01-14-2019, 11:49 AM
Ryanhardt Ryanhardt is offline
Default AAE error -6117 was encounter | Audio Device Loop
When I launch Protools 12.6 HD it get an error loop.
The first pop up message states:
"The selected Audio device could not be initialized. Please choose another audio device."It prompts with QUIT or OK. I click OK.
A new error pops up:
"AAE error -6117 was encountered" It prompts More Info or OK. I click OK. It takes me to the first prompt.
It loops until I click quit.
My audio interface is the Focusrite Scarlett 6i/o. Does NOT work.
I have also plugged it out and just used my normal Windows audio. Does NOT work.
I have also downloaded and installed the ASIO4ALL. Does NOT work.
I have also held in "N". It does NOT work.
Hopefully this message does not just die a virtual/digital death. Please someone.... Help.
best,
Ryan
HP Envy Edition Laptop
Windows 10
Processor : INtel Core i7-4700MQ CPY @ 2.40Ghz
RAM : 8.00 GB DDR3
64-Bit OS
DAW : Protools 12 Perpetual (12.6) HD
Old 01-14-2019, 02:04 PM
Default Re: AAE error -6117 was encounter | Audio Device Loop
Try this:
Uninstall ASIO4ALL
Install the latest Windows driver from Focusrite
Open Control Panel>Sound>Properties
Set windows to use the on-board sound card as the "default playback device"
Now, open Pro Tools and cross your fingers(if its still not working, try holding the N key and open PT again). The idea here is to NOT allow windows to use the Focusrite box(because if/when it does, it prevents Pro Tools from using it).
Pro Tools First: AAE error -6117 loop, Windows [SOLVED] Unnamed Pro Tools | Intro Discussion 19 08-02-2018 05:40 AM
The selected audio device could not be initialized. AAE 6117 error? cvdpoel Pro Tools 12 4 02-23-2018 10:00 AM
AAE -6117 - Audio Device Could Not Be Initialized danevaz Pro Tools 12 2 12-24-2017 11:14 AM
RME BABYFACE audio device could not be initialized aae error -6117 [SOLVED] roachbeatz Pro Tools 12 2 09-26-2015 11:20 AM
Audio Error 6117 PT First laurabeele Pro Tools | Intro Discussion 3 08-13-2015 11:34 AM
