#111
Re: Seriously guys, figure out the Video Engine problem.
Ymmv ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
#112
Your mileage may vary
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
#113
ProRes and DNxHD/R fully encode every frame. This is why the same content will always have a smaller file size when encoded with H264. This is also why Pro Tools performs much better with ProRes and DNxHD/R. Pro Tools does not have to use CPU cycles to figure out what a particular frame in an H264 is supposed to look like. This is just the way it is. H264 requires more CPU power to decode fluidly. If you want a small file size (H264) with performance closer to encoding every frame (ProRes and DNxHD/R), then you could consider creating an H264 file where every frame is an I frame. While this will result in a file that is larger than a standard H264, it may strike a balance between file size and performance. Panasonic markets such a solution for their camcorders as AVC-Intra.
#114
I said earlier in this thread that I'd solved the video engine problem by re-installing drivers etc, but sadly its back.
The only way I can get the rig to run relatively well is to put the video file on the mac trashcan's internal pcie ssd, which is blazingly fast. This allows me to carry on working, but I'm still getting the odd error's. I'm using Pro Res Proxy and tried DNXhd (same result) I got an AJA card hoping that would solve it, but the errors still continue. I'm currently working with Avid support and sending .dlog's etc, I really hope they can get this fixed, its an appalling workflow killer. This whole AVE thing was a massive backwards step when you think how snappy and processor light video playback was in PT10. Anyhow, struggling on.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
#115
Martin - have you tried Video Slave by Non Lethal Applications. Alan Sallabank of PTE swears by it and in his tests it was more stable than AVE (using my SyncOne2 to measure). I can't say any more at the mo...
#116
Sent from my D5803 using Tapatalk
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
#117
Thanks guys.
I tried the demo of videoslave but as I can't get the picture out to my main monitor, it didn't work for me, maybe when they update it? I can't see what its doing that's any different to AVE, which is also essentially a separately running program for hosting video. Although tightly integrated into PT. Why can't they just fix it? Could be back to 12.4 for me, it seemed better and I don't need freeze or collaboration.
#118
#119
Ok, I had another play with video slave.
I forgot I had a separate HDMI out on the mac pro which can go straight to the TV, so that all works great. I had a bit of trouble with the offset for my LCD TV delay though. Where do I set that offset? In PT in the usual place or inside video slave in the prefs? Mike, what offset are you using with video slave for your big monitor and where are you setting it? Just to get me in the correct area, before I correct with syncheck. Other than that it works great, very snappy response and good handling of many different codecs. Although I'd miss not being able to do cheeky edits on the timeline if new chunks of picture come in. Its worth having as a standby for when AVE throws a wobbler, at least I can carry on working! Ta Martin
#120
Pro Tools 11 Mac Video Engine Problem Solved | AllieLaurel | macOS | 1 | 10-14-2014 03:26 PM |
Video Engine not working.. crashing when i load in a video to PT11 | sarahsherlock | Pro Tools 11 | 5 | 08-16-2014 12:35 AM |
PT 10HD with MXF Video wants Video Engine? | rantanplan | Pro Tools 10 | 2 | 06-05-2014 09:50 AM |
PT10.0.1 video engine Mojo SDI problem | Francis Bernier | Windows | 0 | 02-03-2012 02:16 PM |
