Old 07-11-2012, 06:28 AM
joachim's Avatar
joachim joachim is offline
Default Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin
Situation :
Automation Window : only Plugin activated
Audio-Track : with 2 Plugins
1. Plugin : Eq with Notch-Settings, variable in Bypass, Freq and Gain across the Selection, automated
(e.g. for bad Resonance Freqs, differing within the Selection)
2. Plugin : new Eq, that should do a LowCut fixed at e.g. 100 Hz all over the Selection
Aim :
make the necessary Adjustments on the 2.Plugin and write-to-all-enabled in the Selection
without Blowing the Automation of the 1.Plugin
Solution :
1.Plugin Automation-Safe
2.Plugin write-to-all-enabled (Cmd+Alt+/)
Okay. But what if there are 5 Plugins in this Audio-Track, each Plugin with varying Automation ?
Everytime I want to adjust a Plugin-Automation and like to use write-to-all-enabled, I need to recheck, that the other 4 Plugins are Automation-Safe, in Case I forgot.
This can only be done by clicking on each Plugin and rechecking the green "Safe",
there is no Change in Color of the Plugin in the Mix Window, only for Bypass(blue) / Active(white) , not for "Safe".
There is : write-to-current (what is shown in the Track View)
and
there is : write-to-all-enabled (to all enabled Plugins of that Track)
why isn´t there a write-to-all-enabled-but-only-to-the-current/targeted/open-Plugin ?
Or did I missed that (only 4 Years of Experience on Pro Tools, CPTK , currently 10.2, just on an iMac),
could not not find anything in the Documentation, in the Forums.
Are there other Techniques to use write-to-all-enabled , or an Alternative to it (without using write-to-current and Toggling through the Track View) ?
Is there a "Trick" to see at a Glance, if the Plugins are Automation-Safe without opening the Plugin ?
Hoping for Advice,
Joachim
(Post for Student/Indie/Short, very LowBudget)
Old 07-11-2012, 07:33 AM
Sonopolis Sonopolis is offline
Default Re: Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plu
Well you can use Preview, Punch Preview and Write to Selection. This will only affect the parameter you have changed. But it requires HD or CPTK and isn't available as keyboard shortcut.
Drew Mazurek's Avatar
Preview Mode.
www.drewmazurek.com
Old 07-11-2012, 09:48 AM
joachim's Avatar
Smile Re: Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plu
Thanks for the Hint to "Preview Mode".
I did RTFM, but didn´t get the Point (Nonnative Reader). Will do.
Write Automation to All Enabled Parameters in PT9 with mBox, kirka.sainio Pro Tools 9 6 01-11-2013 03:13 AM
Targeted tempo automation? eplust macOS 2 10-15-2012 10:33 AM
Plugin Popping with automation enabled? rob shelby General Discussion 1 09-22-2006 03:52 PM
EQIII automation bug using write to all enabled Matt Chan Pro Tools TDM Systems (Mac) 3 12-23-2005 02:33 PM
Write automation to all enabled parameters? MoviePhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 07:54 AM
