TD-30 and Addictive Drums 2: MIDI notes triggering incorrect sound
I haven't posted here in a long time, trying to be thorough. I am getting incorrect sounds coming back from AD2 when the MIDI input and the map seem to both say the right one should play.
Just picked up a new MacBook Pro (MacOS 10.15 Catalina 10.15.5) and Focusrite 18i8 interface and connecting a TD-30 via USB through a T3 hub. Verified MIDI data is being received by the Mac. I loaded Pro Tools Ultimate and Addictive Drums 2, and checked the mapping between the expected notes for the drum kit pieces (e.g., Tom 1 open hit is D2). I have the insert listening for midi port 10, which is where the TD-30 is sending data. When I hit Tom 1 on the TD-30, I see "D2 127" register in Midi Monitor for both note on and off. But...the hi-hat open sound plays when I hit it. And no matter what I change, it still happens the same way. The kick drum and the snare are correct, but everything else is off or playing hi-hat. I have re-installed the TD-30 driver twice, still the same result. I am about to take up gardening. Any ideas or thoughts on where I may be off?
Dave Cristofaro Pro Tools Ultimate MacBook Pro Late 2019 2.3 GHz 8-Core Intel Core i9 32 GB 2667 MHz DDR4 AMD Radeon Pro 5500M 8 GB Roland TD-30 Axiom Pro 61 |
Re: TD-30 and Addictive Drums 2: MIDI notes triggering incorrect sound
I did some work with ADrums2 and TD10, I think it was, a few years ago. I remember having to edit the midi mapping for some of the drums, and saving that setting. I could also load settings for other brands/models E-drums. The page where I did that was buried quite deep in AD menus, like behind a button on a settings page. Have you seen that page, with the vertical keyboard where you edit the mapping?
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
As an update, I am going to bring my TD-30 in for a check up at a local service center, I think I have an issue with how the kit is working. I will update this thread once I get it back from the shop.
I also used Addictive Drums with a TD10 kit and by choosing the Roland preset in the plugin, ALMOST everything triggered nicely(only pads that were off were the AUX pads). You can go into the Roland brain and change midi note assignments(which I needed to do so I could get either a side stick, or a cowbell on an extra trigger pad). I'd also check out any available videos on Additive Drums 2 as you may find more info than you have right now
Addictive Drums 2 No sound on playback. | Andresen | Virtual Instruments | 7 | 02-16-2018 02:39 PM |
Addictive Drums - No Sound | piwacquet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2011 09:17 AM |
Need a sound replacer to use with addictive drums | progtools | Tips & Tricks | 5 | 12-11-2010 10:09 AM |
Addictive Drums don't play all midi notes? | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2010 12:13 AM |
Incorrect midi notes on mac g4 | lbar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-26-2002 03:05 PM |
