Old 07-25-2013, 02:02 PM
zakco zakco is offline
Default import session data creating unwanted trim automation
Title says it all.
Sometimes when I import session data from a source session that has ZERO automation and NO channels with trim enabled, I'm getting trim automation out of nowhere in the destination session. I can manually delete the breakpoints but it's a real annoyance during tracking sessions.
I need to be able to import "volume settings and automation" in order to bring in multiple cue mixes to the next song.
It will work fine for several sessions and then out of nowhere it starts doing this again.
PTHD 10.3.6
OSX 10.7.3
Dcommand
Is this happening to anyone else?
Old 11-27-2013, 02:51 PM
DanButsu DanButsu is offline
Default Re: import session data creating unwanted trim automation
I'm getting this too, but worse... EVERY parameter gets imported with an automation breakpoint at the same spot (mins:sec 59:33:866). This automation is not present in the original session that I am importing from.
So every send, mute, pan... has an automation breakpoint at that location. Any way to avoid this? To just import the session with the automation already present in it like the OP?
Mac PT 10.3.7 native
OS X 10.7.5
Cheers, Dan
Import session data from PT8 session / pan automation bad jitter Pro Tools 10 0 12-05-2011 06:17 AM
Import Session Data: Automation does not merge? audiosf Post - Surround - Video 8 08-28-2011 03:20 PM
Import Session Data takes in unwanted audio Arno Peeters Pro Tools 9 8 02-09-2011 06:25 AM
Import Session Data & Automation trombino Pro Tools TDM Systems (Mac) 1 10-24-2006 09:21 AM
How do I trim (NOT shift) plug-in automation data on grouped tracks? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-01-2002 08:34 PM
