RAM Recommendations For Sandy Bridge-e
I'm still working on setting up a good Sandy Bridge-e machine and would like to know what you all can suggest in regards to some good RAM for this machine. Is there a big difference for Pro Tools work getting much higher end RAM, especially now that it can be nearly fully tapped into (such as 2133 MHz RAM), or is the additional speed useless and just a waste of money? I will be getting the lower of the 2 Sandy Bridge-e chips, and I will be overclocking it, and possibly the RAM as well. I've heard that overclocking the RAM may not help at all, but in reality, does it? Thank you and I look forward to hearing everyone's recommendations.
Re: RAM Recommendations For Sandy Bridge-e
I'd be interested in the particulars of your build as I'm moving to PT HD Native and will need to build a new box soon. Watching with interest!
Tommy |
I only know that there are kits available from Corsair and GSkill. Other manufacturers will follow suit.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Something to look into..... I have been reading with interest since I had planned on building SNB-E myself. One the reviews I read mentioned that when using all 8 RAM slots (which you really should do the get full bandwidth) the speed drops to DDR3 1333. It wasn't clear if that was a brick wall in the IMC (integrated memory controller) or simply the default for SPD. I would want to know more about that before ordering RAM. If thats the case I would be looking for DDR3 1333-1600 with lower latency.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Technically all the usuals (Corsair, G Skill, Kingston, Mushkin Enhanced, Patriot, etc) have RAM being released for Sandy Bridge-e, however it's just being posted slowly. It's the same thing with the motherboards, as ASRock and many other manufacturers have motherboards that have yet to be posted, including some of the more anticipated ones. I expect to be a trailblazer in a way, however these new chips are for the most part built off of already existing chip series, just expanding on them, so I guess technically I'm more asking in terms of the reputations of the prior series, as although I understand there may be surprises, that at least will help me possibly in eliminating some options (such as if one of the brands is notorious for having poor quality, or if they are known for having excellent quality, as well as if the series these cards are based off is good, then it makes them easier to trust).
From Anandtech
"Occupying the die area where the GPU would normally be is SNB-E's new memory controller. While its predecessor featured a fairly standard dual-channel DDR3 memory controller, SNB-E features four 64-bit DDR3 memory channels. With a single DDR3 DIMM per channel Intel officially supports speeds of up to DDR3-1600, with two DIMMs per channel the max official speed drops to 1333MHz." And "With a quad-channel memory controller you'll have to install DIMMs four at a time to take full advantage of the bandwidth. In response, memory vendors are selling 4 and 8 DIMM kits specifically for SNB-E systems. Most high-end X79 motherboards feature 8 DIMM slots (2 per channel). Just as with previous architectures, installing fewer DIMMs is possible, it simply reduces the peak available memory bandwidth." I would wait a week or two and see what other reviews get posted and what speed the RAM is running when all the slots are populated. And what timings it prefers. Full article Here
If you want to use full 8 memory slots such as 8x8GB=64GB with higher speed, memory rank matters, so you may need to choose Single Rank memory modules, but some motherboard maker like ASUS seems to officially support Dual Rank memories.
I intend to use all 8 channels, most probably getting 2 4x4 kits, or an 8x4 kit if it's available (whichever's cheaper), so I don't know how concerned I am about that. I've been looking into getting 8 4GB cards at 2133MHz probably.
I'm waiting for Microcenter to offer them at 499.00
Motherboard Recommendations for Intel Core i7-2600K Sandy Bridge 3.4GHz | xstortionist | Pro Tools 10 | 0 | 04-19-2013 06:39 AM |
Duo Core to I7 Sandy Bridge | Liquid Ghost | Pro Tools HDX & HD Native Systems (Win) | 9 | 10-01-2012 10:18 AM |
Which motherboard for i7 Sandy Bridge | albee1952 | Windows | 15 | 09-14-2011 07:34 AM |
Sandy Bridge | Gravyblue | Windows | 0 | 06-06-2011 12:12 PM |
Sandy bridge CPUs - what to expect? | SixChurchStreet | macOS | 1 | 01-27-2011 01:06 PM |
