This type of problem only came as a result of Avid moving to support the PC, the most notoriously 'open' platform available with nearly no standards. So you get to pay 'half' for your computer than a Mac would cost - but you get 'double' the problems making Avid's software/hardware work. All of life has trade offs, gang. Not to start a Mac vs PC debate. But we have to call things what they are.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
Re: Disgusted. Returning this product
I've also run into a number of occasions where you needed to disable networking on a Mac. In fact, as I recall, this was always recommended by Digidesign from the very beginning. (I had serial #130. and was, among other things, the very first person to ever use ST and PT at Skywalker Ranch.)
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Have a good day, Bob! Grant
This is very interesting reading. Thanks for posting, guys. As for my problem, my hardware conforms to what is needed. I checked before I installed all this a couple of years ago. Had my machine running along happily, then, after a couple-of-months lay-off from using ProTools, a project comes up, go to start PT, and BAM.... Nothing happens. Admitedly, this machine is a multi-tasker, and any installed program (God knows what) could be argueing w/ PT. I just don't have the resources to have a dedicated machine.
#16
I'm running a PC and don't have my ethernet card turned off. I have minimal concern over most other optimizations. I've had fewer problems than most with PT 8 or 9 and I built this machine. Not to say that Macs aren't made for this stuff it's just that a good PC can be made for this too. It's all a matter of operator error afaic. That and the fact that the PC world is so full of cracks and garbage that people insist is safe. Then when they find out that something doesn't jive, they blame hardware or anything other than the software they stole. Not saying the OP is using cracks. I'm just saying it happens more often than not.
Intel i7 4770 Dell XPS 8700 16 Gig DDR3 1 x 1TB System Drive 1 x 320Gig Seagate HDD 1 x 500Gig Seagate HDD UAD-2 Solo Steinberg UR44 KRK RP5 Windows 10 Pro. 64 bit Sonar Platinum Cubase 8 Sony Acid Pro 7 Sampletank 2 XL EZDrummer Guitar Rig 5 ProTools 12.3 All legit software thank you very much. Yes I have a low post count but only because I don't have a lot of problems with my gear. |
#17
http://duc.avid.com/showthread.php?t...=compaq+laptop
Sometimes you really have to work hard to make it NOT work...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Where do I get my account with product info if registered a boxed product? | lanstrad | Pro Tools 9 | 3 | 08-30-2011 09:36 PM |
Simply Disgusted | sriks | Windows | 30 | 05-04-2011 02:52 PM |
The product activation site is currently returning "database error" for all logins. | corywest | General Discussion | 4 | 11-15-2009 11:54 PM |
Too disgusted with DIGI DESIGN to build | Soliloquay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 62 | 06-23-2009 07:20 AM |
returning to zero | DJ Insomaniac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-02-2004 02:40 PM |
