Old 04-28-2002, 12:27 AM
yin7yang64 yin7yang64 is offline
Default Time to reinstall the software?
A bit of weirdness in my beige G3 setup (PT 5.0.1, OS 8.6). I went to work on a project tonight and I couldn't get the Factory Settings to load on any of the AudioSuite plug-ins. My own customized settings were there and worked just fine, but although the Factory Settings were listed on the pull down menu, the parameters wouldn't come up on the control panel when I selected one.
I also discovered tonight that I couldn't get the Clear Selection command to work from the keyboard. Usually it's a highlight file, then type Command+Shift+B. Tonight it wouldn't respond. I had to find Clear Selection in the Audio File bin pull down screen to get the job done.
Apart from these anomalies, the six-hour recording and mixing session went just fine--no other weirdness. To be on the safe side, I'm wondering if a fresh installation of my ProTools software would make sense. Or should I trash some preferences first? Or is there another fix worth considering?
Old 04-28-2002, 02:47 AM
OgnKog OgnKog is offline
Default Re: Time to reinstall the software?
I think you're problems are not weird enough to reinstall the software... (though it's never a bad moment to do it... i almost do it once every month)
The problem with AudioSuite may come from a bad root folder assignment... check it out on the AudioSuite pop up menus...
Al.
We are all in this together.
Old 04-28-2002, 04:58 AM
vf124 vf124 is offline
Before a clean install, I would try the "virgin" DAE ƒ thang 1st...
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !!
software reinstall help! Kemo3ce Pro Tools M-Powered (Mac) 2 12-13-2012 08:34 AM
Cloning software OK or full reinstall of PT9? LaurentC macOS 1 10-26-2012 02:38 PM
Must reinstall software, third party plugins? natural 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-30-2005 09:52 AM
Reinstall software message Esteban WB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-13-2003 12:54 AM
How do i reinstall a demo after the time runs out? XHipHop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-25-2002 12:13 AM
