Old 04-09-2016, 04:52 PM
take77 take77 is offline
Default Can't change external volume from "T" to "R" in workspace. [SOLVED]
Hello,
I'm on Windows 7 and trying to configure an external 7200rpm USB 2.0 drive for use with PT12.4.
The drive is formatted for NTFS.
The drives partitions are greyed out under "offline volumes" and the "permissions" options are also greyed out not allowing me to change T to R.
Does this mean that a USB 2.0 drive is not compatible with PT12.4 on a Windows 7 system?
Thanks.
UPDATE: It is now working correctly. I deleted each partition volume and reformatted. Will try to create the new partitions and see what happens.
The full volume now indicates an "R" by default:)
Now the test of seeing what kind of audio throughput I can pull off using USB 2.0.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Cannot Change "P" to "R" in workspace. theprof_to 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-08-2009 12:24 AM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
