  #21
Old 09-05-2013, 12:58 PM
Default Re: Blue Cat MB-7 v2 Multiband Mixer
Originally Posted by bluecataudio View Post
Thank you guys for mentioning our plug-in! It can indeed host VSTis, even if it was not initially designed for that:multiband VSTi hosting has not been defined yet .
All I can say is thanks for this plugin as it helps take care of things I've been trying to cobble together for doing a multiband compressor. Long been a fan of Blue Cat plugs.
Jack
QAPLA!
  #22
Old 09-05-2013, 01:36 PM
Simon Morrison's Avatar
Simon Morrison Simon Morrison is offline
I can confirm that VSTi's work perfectly in MB-7 V2:
1. Create a normal audio track
2. Insert MB-7 V2
3. Load a VSTi (in MB-7)
4. Create a new MIDI track
5. Set the MIDI output (of the MIDI track) to input Channel 1 of the MB-7 audio track
6. Record enable the MB-7 audio track
7. MIDI input or MIDI data will trigger the VSTi
Simon Morrison • Audio Architect • Mastering Engineer • Music Technologist
Pro Tools Studio 2024.3 | macOS 14.4.1
[ www.MorrisonStudios.com ]
  #23
Old 09-05-2013, 01:51 PM
Update:
Originally tried with PT 10.3.6 and all was well, then I updated to PT 10.3.7 Plugin does not seem to play well with PT 10.3.7; several sbbod when I tried to switch presets in MB7 or change from another plug to MB7 and had to force quit PT. But when I re-opened PT and tried to re-create the sequence of operations that caused the crash it wouldn't happen. Just to be safe I went back to PT 10.3.6
That said I really do like this plugin. Lots of great possibilities.
Jack
QAPLA!
  #24
Old 09-05-2013, 02:36 PM
RyanC RyanC is offline
Interesting will this load plugs that are vst3 only? IE autotune 7?
  #25
Old 09-05-2013, 02:46 PM
WorldStudios WorldStudios is offline
Originally Posted by Southsidemusic View Post
How would that work as I also want to use Sylenth1 in 11 ..
Do you mean that the Multiband compressor can open VI's
Its a multiband split box. If you leave only one band full range and insert a vst effect it works as a host and processes the input audio.
As a funny side product, it opens vst instruments as well and then you send midi to it and it just works. From what they say...
Now with a bridge from 32 to 64 in between you can even run 32 bit plugins and instruments, but I must say there are many steps and processes running. I want to see that working smoothly before I believe it! :)
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #26
Old 09-05-2013, 02:55 PM
Southsidemusic's Avatar
Ok Thanks. Sounds a bit off to me for now and we will keep using reaper for the synths not yet ported to AAX64 but thanks for the info.
Take Care
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #27
Old 09-05-2013, 02:59 PM
cryophonik's Avatar
cryophonik cryophonik is offline
Not sure about you guys, but I'm most interested in the creative aspects of this plugin, i.e., processing different frequency bands individually for some wild effects. If any of you have ever used plugins like Obelisk from Artificial Audio, then you know what I'm talking about. The MB-7 would be like that on steroids. Hell, I just realized that I can actually load Obelisk (VST-only) into the MB-7!
  #28
Currently only VST 2.4 is supported.
  #29
Old 09-05-2013, 07:24 PM
Update to my post #23 here:
I think I narrowed it down to a strange interaction between ikmultimedia TRacks CS and MB7. I would get consistent PT lockups if I tried changing the plugin via the selector in the plugin's gui in the upper left hand corner. If I went to the track insert and changed the plugin there I wouldn't have a problem. Didn't have to delete the plugin and then insert another plugin, I could just change it and it was okay. Haven't seen this weirdness in any other plugins (yet as he knocks on wood and throws salt over his left shoulder with his right hand). This is on PT 10.3.6 which gave me the same problem I had in PT 10.3.7. Will try PT 10.3.7 and report back if I have any more problems.
update to the update:
Appears to work just fine in PT 10.3.7 given what I mentioned above about changing the plugin from the Insert slot and not from the plugin's gui. Please let this be the end of problems. Doing this back-and-forth dance while watching Djokovic trying to beat Youzhny. Novak wins first 2 sets, loses 3rd and appears to be making a comeback in the 4th.
Jack
QAPLA!
  #30
Old 09-05-2013, 08:45 PM
I was all into your post and following well until you hit the metaphor at the end......LOST ME.......
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
HTML code is On
MultiBand Comp.. xy44 AAX Plug-ins 9 10-25-2013 09:26 AM
Multiband Compressors Jmmergens RTAS & TDM Plug-ins 4 05-01-2013 04:19 PM
How do you use multiband compression Ben Jenssen General Discussion 23 08-23-2001 05:04 AM
MCDSP Multiband buvaudio Tips & Tricks 6 03-29-2001 08:15 AM
