Offline Bounce and Automation
Hi guys so I'm trying out the Protoools 11 trial version
I (OFFLINE) bounced a vacuum bass line with modulation and notice that it doesn't pick up the modulation which is the mod wheel it does however work if i bounce it normally without using the offline feature any ideas what it could be? |
Re: Offline Bounce and Automation
ANyone?
I'm not sure what you are trying to do but as you know, the offline bounce will work with plug-ind but not any external boxes. So if you are doing something "outside the box", it won't work for offline bounce.
Sorry if I don't understand the question.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
ok I'm using the Vacuum virtual instrument and I'm using modulation
to change the sound filter. it sounds awesome but when i offline bounce the track the resulting audio is not what i had intended it has none of the modulation, but if i bounce it out normally it works fine |
Is the offline bounce designed to use with all VIs? Can you change the VI MIDI to audio? It would work then, IMHO.
Where is the interest of offline bounce then?
Fir3bird ----- PT 10 & 11 / Octa-Capture Vaio Z (Win7 64bits) Full details on my profile... |
It Doesn't make sense to have offline bounce and you can't change parameters, either i am doing something very wrong or protools 11 offline bounce sucks HUGE!! I'm sure I'm doing something wrong though Surely you can bounce instruments, and effects and modulation and reverb / delay changes
Did a quick test and I can confirm that with Vacuum doing a offline bounce the modulation data does not translate. Doing a regular realtime bounce, it does.
Offline bouncing does work with pitch bend. Has to be a glitch that Avid over looked. CC#1
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
This should not happen with offline bounce. Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
That seems to be it well spotted how do we make this known ?
Offline bounce bug ? | deardaddy | Pro Tools 11 | 20 | 12-28-2016 02:43 PM |
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
offline bounce? | danielfre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-28-2006 02:04 PM |
Offline Automation Trimming | BillSmith | Pro Tools TDM Systems (Mac) | 8 | 12-08-2003 05:23 PM |
