Old 01-03-2013, 02:05 PM
kevinpierce93 kevinpierce93 is offline
Default Have to reinstall PT HD Driver every time i unplug Mbox
Everytime i unplug my Mbox 3rd generation from the USB on my macbook pro when i plug it back in the power light on the mbox flashes blue and it won't work with pro tools, i found that reinstalling the Pro Tools HD Driver fixes it but its annoying having to install it everytime i have to unplug my mbox, also i have tried the safe eject USB thing and it still does it.
Old 01-03-2013, 06:04 PM
sunburst79 sunburst79 is offline
Default Re: Have to reinstall PT HD Driver every time i unplug Mbox
Help Us Help You.
Some info would be as they say...useful.
AFAIK you shouldn't be installing the HD driver. You should be installing the correct driver for your hardware. I would start with the Driver Updates heading at the top of this page.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-03-2013, 07:32 PM
I have all the drivers for the hardware updated, its the Pro Tools HD Driver that i have to reinstall every time i unplug the mbox and plug it back up, and what other info do you need?
Old 01-03-2013, 08:11 PM
There is also an Mbox driver(but maybe you got that already). I believe the HD driver belongs in there as its on my system(with 003) and works fine). 2 things come to mind on this; Are you always using the same USB port(when you find one that works, use it every time), and are you connecting the Mbox with the computer already ON?(if so, shut down>connect the Mbox>restart).
Old 01-04-2013, 05:22 AM
Exactly.
Windows can be finicky with USB ports & changing what's plugged into them.
Jack
QAPLA!
Old 01-04-2013, 08:51 AM
Thanks for the help everyone, I figured out it was cause I was changing ports every time, stupid post -_- haha
Old 01-04-2013, 09:12 AM
That would do it. FWIW I've plugged and unplugged My MBox2 into every port on a computer before. Once the computer has run the new hardware wizard for that articular piece of hardware on each port it tends to remember it and not require running the installer at a later date.
Scott
Core 2 Specs Page
Is it ok to unplug my Mbox 2 when the S/PDIF LED light is flashing Gary Gould 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-24-2012 07:51 AM
Is it ok to unplug my Mbox 2 when the S/PDIF LED light is flashing Gary Gould 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-13-2012 05:45 AM
Cant reinstall M-powered driver! vieris Pro Tools M-Powered (Win) 1 07-27-2005 04:23 PM
How To Properly Reinstall Wave Driver? mfym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-07-2001 05:48 PM
