Old 05-14-2012, 01:28 PM
crizdee's Avatar
crizdee crizdee is offline
Default Quicktime bounce video out of sync
Everything is in sync whilst in PT but when bounced its out of sync?
I guessing its something to do with ADC or plugins on the mix bus? Anyone found a work around?
everything is set to 25 frames
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-14-2012, 03:17 PM
Ray JB Ray JB is offline
Default Re: Quicktime bounce video out of sync
Are you running a video offset?
Old 05-15-2012, 12:08 PM
crizdee's Avatar
No. is that in the session setup window/syn video and time code offsets.
Not sure how i would calculate an offset? is it to do with the plugins on the mix bus and delay comp etc. I'm guessing its related to that as i think it works if there are no plugins on the mix bus or master output.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-21-2012, 02:39 PM
Hey Chris
Sorry to be slow in replying. I paste this from the latest Readme from ProTools 10.2 release notes..
Video Offset affects Bounce To QuickTime files (PTSW-123033)
If Pro Tools has a defined Video Offset and you Bounce to QuickTime, the resultant QuickTime file will be offset by the specified amount in Pro Tools (Setup > Video Sync Offset). To avoid this problem, set the Video Sync Offset to 0 before bouncing to the QuickTime file format.
This is from "Pro Tools 10.2 and Pro Tools HD 10.2 on Mac OS X 10.6.x (“Snow Leopard”) and 10.7.x (“Lion”) — 5/8/12" readme but it's been in other earlier versions as well.
Is this what you are seeing?
Old 07-17-2012, 12:52 PM
stevedresser83 stevedresser83 is offline
im having the same problem. Quicktime video imported into PT's and everything is sync'd. Audio i created to the video matches how i want it. When i bounced all my audio plus the audio from the quicktime movie is delayed maybe 2 sec or something. I have no video sync offset on. Any help?
Old 01-15-2014, 02:33 PM
K Roche's Avatar
K Roche K Roche is offline
Interesting am have a similar issue ( sort of) I can import a QT screen recording but when I bounce back out to QT It does it and I can open the movie in QT but it will not play it just stays on the first frame ???? I posted over in the PTHDx and HD Native on Mac forum but no replies so far. Ill check the sync option but it doesn't quite sound like the same problem
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 06-12-2014, 02:17 PM
Redmann Redmann is offline
It could be ADC causing this but often times it's if the sample rate isn't set in bounce to quicktime the same as it is in the session.
Q re video sync (Quicktime) billsincl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2008 11:10 AM
Quicktime movie bounce out of sync SamZ Pro Tools TDM Systems (Mac) 6 03-19-2008 04:16 PM
Bounce To QuickTime Movie - No Video nhaudio Pro Tools TDM Systems (Mac) 4 05-31-2007 07:20 PM
quicktime video in and out of sync inky Pro Tools TDM Systems (Mac) 23 05-24-2005 08:57 AM
Bounce to Quicktime= No Video violentfingers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2004 01:22 PM
