Old 09-22-2009, 07:10 AM
KKalampo KKalampo is offline
Default Pro Tools HD with Intel i7 cpu
Hello,
I'm thinking of buying pro tools hd and my pc consists of a motherboard with CPU Socket 1366 and the Chipset Intel X58 Express and an Intel i7 cpu. Does anyone know if pro tools will run without problems in my system?
Thanks for you help.
ps I'm using windows xp
Old 09-22-2009, 09:33 AM
Default Re: Pro Tools HD with Intel i7 cpu
LE runs great on the i7/X58 setup so I would expect good results for you.
Old 09-22-2009, 11:58 AM
sunburst79 sunburst79 is offline
It needs to be said that you need a motherboard that will physically accept the HD cards without interference regardless of whether they are PCIe or PCI.
If PCIe you need be able to set the slot speed to PCIe X1 or X4 as apparently the cards will not work with PCIe bus speeds of X8 or X16-or so I have heard.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 09-22-2009, 09:27 PM
riffmachine riffmachine is offline
Originally Posted by KKalampo View Post
Hello,
I've got the i7 cpu and for some reason I had problems installing the 8.0cs3 update. I have a Sweetwater Rack XT and their support team figured out that the cs3 update would not work with the i7 for some reason, so I stayed with cs2 which worked fine. For 8.0.1 I had a couple crashes while trying to install, but I was eventually I was able to get HD working. Other than that, no problems.
Old 10-09-2009, 11:05 PM
anthumr anthumr is offline
Hey riffmachine, I was reading that you got your Pro tools HD to work with the i7 processor. I am about to build a PC for Pro tools HD and would like to know the specs of your computer system and what version of operating system, what kind of mother board and all that your using to get it to work. Thanks, hope you can get back at me asap
Old 10-09-2009, 11:17 PM
Hey KKalampo I would like to know your system setup as well, please im trying to build a PC for Pro tools HD. If you built one that you mention how did everything turn out? and trial and errors? Please help
Old 10-13-2009, 12:39 PM
Can anyone give me there PC system information, motherboards, Processor, rams, OS type all of the information necessary to build a PC Pro tools HD system. Pleaseee thanks. I would prefer the intel i7 build please.
Old 10-13-2009, 09:26 PM
Mike Stosich Mike Stosich is offline
About 4 months ago I assembled my new system to accomodate 8.0 and my HD1 stystem. Emphasis was placed on being QUIET! I made only one mistake the PS is a bit too loud. Anyway, it is basically quiet and is speedy.
Intel I7 920 uP
Noctua NH-U12PSE cooler
ASUS P6T MB
6 GB OCZ DDR3-1600
WD320 GB 7200RPM 16 MB SATA2
Antec WE 750 W
Antec P182 case
BFG NVIDIA GeForce 9800GT 512 MB
Samsung SH-S223B DVDRW SATA
BYTECC 1.44 MB
BYTECC 3.5 I/O
M-Audio 2496
Vista Business with W7 update coming
Mike
Mike Stosich
Old 10-13-2009, 09:58 PM
Intel I7 920 uP
ASUS P6T MB
6 GB OCZ DDR3-1600
Antec WE 750 W
Antec P182 case
BYTECC 1.44 MB
BYTECC 3.5 I/O
M-Audio 2496
Mike
Hey Mike,
The Corsair HX 620 is really quiet.
Scott
Core 2 Specs Page
Old 10-18-2009, 09:38 PM
Intel I7 920 uP
ASUS P6T MB
6 GB OCZ DDR3-1600
Antec WE 750 W
Antec P182 case
BYTECC 1.44 MB
BYTECC 3.5 I/O
M-Audio 2496
Mike
Hey Mike, Were you able to run pro tools HD1 with a 64 bit version of Vista Business or are you running a 32 bit OS. Also when you say W7 update what did you mean by that? thanks for the system info by the way, I'm considering buying the same setup you have, but I was also wondering if there was another mother board that might support more then 1x PCIe slots, because i see that theres only one slot only with the Asus PT6. I want to have the option of upgrade to a HD2 later on, so what other motherboards would you recommend? Thanks a lot for the information. One more questions, how well is your PC running with the HD1 setup. THANKSS
pro tools 6.1 and intel i7 barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-04-2010 05:03 AM
Intel X-25M 80 Gig SSD and Pro Tools LE! gearhead2010 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-20-2010 12:40 PM
GRM Tools go Intel mindnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-27-2006 05:51 PM
GRM Tools for Intel Mac whtrabit Pro Tools TDM Systems (Mac) 0 12-27-2006 05:36 PM
intel and pro tools? LadyElectrikStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-20-2002 04:21 PM
