Old 01-28-2009, 04:22 PM
chrono4548 chrono4548 is offline
Default Pro tools 8.0 crashes out of no where
I have a Mac Pro,
2x 2.66 ghz dual core intel xeon,
with 2 gb 667 mhz of ramm
Pro Tools LE 8.0cs1
I have pro tools LE 8.0cs1 and when I open a session if i have 1 to 3 plugins inserted my rtas meter peaks which makes pro tools crash. This isn't just doing it with certain plugins if i just insert 1 to 3 plugins my rtas cpu just peaks. I can easily use 50 plus plugins with out a problem and now with 1 to 3 plugins my system is having a hard time.
Has anyone have this happen. I have reformatted my hard drive, trash prefs, i upgraded to 8.0cs1. this had just started happening out of no where my system was running great ever since i upgraded to pro tools 8.0 and now i can't even really run my system
Old 01-28-2009, 11:33 PM
Default Re: Pro tools 8.0 crashes out of no where
Well i unstalled and reinstalled pro tools still having an issue. I am having an issue with the buffer size. I usually can run at least 30 plus plugins. Now i slap on my eleven plugin and it makes my system crash. i usually can run 5 sets of eleven with out a problem. I upgraded my emerald pack for my mcdsp plugins. I am also having issues with option dragging plugins for duplicating the on tracks. it makes the pop up saying increase your buffer speed. Anyone have any solutions?
Old 01-28-2009, 11:36 PM
also my rtas cpu should be around 7% but just out of no where jumps up to 100% and crashs
Old 01-29-2009, 05:32 AM
dogon dogon is offline
What interface?
What drives?
Old 01-29-2009, 06:11 AM
dougied dougied is offline
What version of OSX?
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 01-29-2009, 08:54 AM
DigiTechSupt's Avatar
Have you done all the General Troubleshooting steps, including making sure that all installed plug-ins are the minimum version required?
Can you use the Tech Support Utility to post a list of installed plug-ins and their versions?
Avid Audio Tech Support
Support FAQ
Old 01-30-2009, 08:10 PM
Fri Jan 30 20:06:53 PST 2009
Pro Tools Version
__________________________________________
Pro Tools LE.app
8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
AIRChorus.dpm
1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc.
AIRDistortion.dpm
AIRDynamicDelay.dpm
AIREnhancer.dpm
AIREnsemble.dpm
AIRFilterGate.dpm
AIRFlanger.dpm
AIRFrequencyShifter.dpm
AIRFuzz-Wah.dpm
AIRKillEQ.dpm
AIRLo-Fi.dpm
AIRMulti-Chorus.dpm
AIRMulti-Delay.dpm
AIRNon-linearReverb.dpm
AIRPhaser.dpm
AIRReverb.dpm
AIRSpringReverb.dpm
AIRStereoWidth.dpm
AIRTalkbox.dpm
AIRVintageFilter.dpm
BF Essential Clip Remover.dpm
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
Boom.dpm
Chorus.dpm
Click.dpm
D-Verb.dpm
DB-33.dpm
DigiReWire.dpm
Dither.dpm
Dynamics III.dpm
EQ III.dpm
Elastic Audio.dpm
Eleven Free.dpm
Flanger.dpm
Invert-Duplicate.dpm
LoFi.dpm
Maxim.dpm
MiniGrand.dpm
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Ping-Pong Delay.dpm
RectiFi.dpm
Reverse-DC Removal.dpm
SansAmp PSA-1.dpm
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
Structure.dpm
1.0.2.7584 Copyright 2008 Digidesign, A Division of Avid Technology, Inc.
TL AutoPan.dpm
TL InTune.dpm
TL MasterMeter.dpm
TL Metro.dpm
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
8.0.0, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
Trim.dpm
Vacuum.dpm
VariFi.dpm
XPand!.dpm
2.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc.
bombfactory BF76.dpm
Plug-Ins Unused Versions
BF Essential Tuner.dpm
Dynamics II.dpm
EQ II.dpm
Funk Logic Masterer.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2 is not installed
Digitranslator 1 is not installed
Complete Production Toolkit is not installed
Old 01-30-2009, 08:12 PM
Also i have pro tools 8.0 running on a mac pro with 2 gigs of ram. I have a digi 002. I did a fresh install of leopard and have have 10.5.5 with the combo update and also i did a fresh copy of pro tools. I trashed prefs as well.
Old 02-03-2009, 11:45 AM
RandB RandB is offline
For what it's worth, I've also had Pro Tools 8 crash unexpectedly (as if it has ever crashed "expectedly" before).
I'm running it on an iMac, Intel 2.8 GB processor, 4 GB RAM, data to external firewire (Glyph) hard drives, 003 Rack daisy-chained after the externals. OSX 10.5.6.
Never had this happen with 7.4.2.
And I'm not running nearly as many plug-ins at one time. But I do know that they're all current versions.
Randy
8 Pro tools crashes in 1 day?!!? iamnightfall macOS 21 09-26-2013 03:01 PM
Mac OS X 10.6.2 crashes with Pro Tools 8 NikoNewYork 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2010 11:40 AM
Pro Tools 8 Crashes Hudson Handel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2010 10:33 PM
Pro Tools CRASHES my PC XyberICE Digidesign Hardware & Software 4 05-07-2005 03:44 PM
Pro TOOLS 6.1 some crashes. BoRiZ KukoBa Pro Tools TDM Systems (Mac) 0 09-17-2003 03:44 AM
