Getting Roland Vdrums into 192I /O
My old and feeble mind reaches out to you with active brain cells.
My Roland Vdrum TD-10 outputs +4 dbm (not dBu) nominal. Impedence is 330 ohms and is unbalanced. If I remember correctly, dbm is roughly 3/4 of dBu, but I would really like to know which input to use and how to set the proper level into my 192. Go to it folks! |
Re: Getting Roland Vdrums into 192I /O
use a mixer. you will be able to match impedance and set levels, maybe even submix and output the proper levels to your 192. It's really handy. you may need some devices similar to a DI if you want to send mic levels to the mixer. Have fun.
love and light |
I use Digi Mic pre..it has -10 imputs .as well as +4... and my V drums have all the gain you need..........
Midi hits with roland Vdrums | Raoul23 | Virtual Instruments | 0 | 08-07-2013 12:29 PM |
Does anyone know a good way to map Roland Vdrums to Strike | digi2000 | The Drum Room | 2 | 06-03-2012 01:22 PM |
Recording Roland VDrums via 002 MIDI | RynoTH | MIDI | 4 | 03-29-2005 08:36 PM |
basic MIDI setup w/ roland Vdrums | whatwhat | MIDI | 1 | 03-17-2004 09:20 PM |
Roland Vdrums and Midi Setup | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-17-2004 04:59 PM |
